Someone put my mind at ease!
The point is to have the right pad for the finish, the right products, technique that You use, You skill.
Wax/polish only hides swirl marks, You need to make sure You REMOVE them, not hide them. It also depends on Your clear coat condition.
I know what I am talking about, I think I buffed half of the cars in my state over the years
If You live in IL, I could do it for ya.
A wax can hide swirls of course.
1. The lovely thing about the PC is that even with the harshest pad and polish it will abrade only so little at a time... In other words, many clearcoats can withstand a large amount of PC work before there is none left, viz. VERY little clearcoat reduction will occur... In fact, sometimes not enough, which is why many people get swirls a PC cannot remove.
If we were talking about a rotary buffer or wetsanding, it's a whole different story... So for touch-ups it seems you're KIND OF safe, but this leads to another consideration... Which is
2. WHY? Why so many swirls? I'd definitely look very closely at your washing/waxing routine for culprits that lead to swirls. Once discovered, you could eliminate them and not have to worry about swirl removal AS OFTEN.
edit: and like i said in a month my car will be fair weather only. as of now i only drive it when it isnt raining, but i park it at work for 5 hours a day where its surrounded by gravel parking lots, alleys, etc.
So, then what's the point of this topic?
Is your question if once a month will rapidly diminish your clearcoat with the PC and FPII (I'm assuming white pad here)? If so, then not to the degree I would worry about... I'd certainly have other worries instead, but hey, I'd hate to patronize/condescend ya.
Well, this one I have to mention: If you're swirling your car with Quik Detailer and a premium microfiber, you're doing something wrong there with the actual wiping and/or with how you're sealing the paint after the FPII... Don't mean to imply you are clueless or anything, ok?
The only thing you can truly and effectively layer on a pure carnauba is another pure carnauba. You're trying to layer a polymer sealant (NXT) that has some cleaning properties... You're probably both cleaning the #26 RIGHT OFF... AND tacking on an improperly set layer of NXT that could not bond properly to the clearocat...
The NXT, which I think is an awesome product, should be applied to the clearcoat directly. Doing so will create a seal that can last for 6 months or so of excellent protection. This is of course applied only to a proper application, viz. Polymer sealant applied directly to bare, uncontaminated paint and then allowed to cure properly.
Any pure carnauba with no cleaners that can layer can then be set ON TOP OF the NXT, unaffecting it, not disturbing the seal of protective topcoat.
What you're doing now, basically, is applying a layer of pure carnauba (which looks great but can sometimes be washed off in ONE RAIN or a couple of day's worth of sun... High melting point) and then applying NXT which cleans OFF the wax you just set, which is then improperly set itself! Afterwards, since your car is not effectively sealed and the paint is unprotected, swirls in the clearcoat are easily inflicted, e.g. with a microfiber and Quik Detail spray, for instance... You need to reverse these steps immediately.
edit: look at this....ironic huh?
https://ls1tech.com/forums/appearance-detailing/737952-porter-cable-buffer-effects-clear-coat-surfaces.html
