Installed stripes... got some lint under them...
and there are now some small bubles
Is there any way to get them out, or do they go away after a while? I'm guessing it's just air though.
I use a squirt bottle and water with a few drops of soap in it. That way you can hold the decal in place once you get it on where you want it, and squeege it out at the same time. I use a 3m rubber squeege that someone gave to me, but any rubber or flat plastic will work. As for the bubbles, a sharp pin/needle will do. Just like TDOFW said, poke a tiny hole and push the excess water out. I'm guessing that's all it is since you said you cleaned the decal and car surfaces before hand. Good Luck,Rob
A pin will create a "puncture wound" which will remain visble because it stretches the vinyl. Put the car in the sun so the vinyl will get good and hot (stretchy). Use a brand new #11 Xacto blade and carefully poke the bubble near an edge and push the air from the other side towards the hole.
