Wire mod issue!! Need your help please!
Thanks, any help is appreciated!
FYI
I was a little concerned about adequate protection for the cables and vac hose so I ran everything through blue "2" Economy Discharge Hose". This is the super flexible hose used for pumping out pools. It is flat when water is not being pushed through it. I think it is going to work great. It runs from just inside the engine bay near the PCM to the battery. I wrapped the cable bundle/hose at the PCM tightly w/ black electrical tape to help keep water out and cover up the blue hose at that end. If you try this, I would suggest the next larger size. 2" hose is a PITA to get all the connectors through. Good luck.
