tried search, t/a door panels in camaro ?'s
ok so i installed the t/a door panels in my camaro, well ya know you have to cut out the 2 brackets on the actual door to make the panels fit, how do you brace that up at all? anyone have any ideas? ive looked i have a few ideas, but on something like this id rather go with experience thanks in advance fellas, and ladies
what i did was put the t/a panel on, and get a long drill bit and drill a small tap hole through where the screws will go, one behind the handle cup, one underneath the door handle inside, and one in the map rack thing at the botton, then pull the panel off again, ummm i hope you saved your old black screw brackets, they were on the arms you cut off the origional panel, then drill a hole big enough to pop them in, the bottom one you will need to cut to fit because it will overhang the bottom of the door, i'm sorry i don't have pix, but if you need more help pm me, and i'll give you my number or whatever you need, either way mine came out ok,
