Headlight question..would it be possible
Old Jul 18, 2007 | 03:30 AM
Kewl_Blades's Avatar
Tdawg:
Are your Halos LED or CCFL?
How hard is it to take out the Halo Rings?
Is it possible to measure the high beam/low beam rings? inside diameter, of course.
Basically what I am getting at is this:
If they are LEDs, changing out the LED bulb would be simple when they fail or when a new color is wanted. And if the ring broke, a new one could be a DIY ring.
If they are CCFL, then a new CCFL tube would be needed for either a replacement or a new color. As far as I know, you cannot DIY a CCFL.
I like the style but do not like the white halos. I prefer CCFL over LED for luminance but stock/custom CCFL tubes bent in a particular diameter circle are hard to come by. If someone would be able to measure their Halos on the projector headlights (like Tdawg), I would be able to find the correct CCFL rings in a varity of colors and other LS1tech-ies would have a choice other than the stock white CCFL.
Old Jul 21, 2007 | 06:01 PM
Tdawg's Avatar
The Halos are CCFL, on taking them out i have no idea haven't tried yet but eventually i will, i want to put blue in there instead of the white. i'll try as soon as possable to get those measurements for you, unless someone else gets it done before i do...
Old Jul 22, 2007 | 05:23 PM
Get me the measurements and I'll do the work in getting different colors for all the LS1techies.
If you might think it will take more than a month to get the rings out, I'll just buy a set and measure it all out myself.
Old Jul 24, 2007 | 03:05 PM
1999Z28's Avatar
http://cgi.ebay.com/ebaymotors/98-02...QQcmdZViewItem
I wrote this guy and he said they show up blue like in the picture...but I almost figure that one company makes them all...so how do his light up blue?
Old Jul 24, 2007 | 05:40 PM
Tdawg's Avatar
The halo's have the reflection off of the blue leds which gives it the illusion of the blue rings, it's really decieving haw they did it , they ARE all made by the same company. i've talked to several companies and have bought and gone through several pairs, cause i couldn't get the projector to point the right way without the gap. finally i just modded the brackets myself.
Old Jul 24, 2007 | 11:42 PM
are any of those "pairs" available or were they returned?
Old Jul 25, 2007 | 01:12 AM
Tdawg's Avatar
they all got returned, couldn't afford more than one pair , that and i didn't want to deal with the defective ones that none of the companies wanted to help try to fix
Old Jul 25, 2007 | 01:33 AM
1999Z28's Avatar
I had to use my original brackets on my old style halo's bc they fit like poop. Did you try that or were they worse? I was hoping this new style projector was a decent product.
Old Jul 25, 2007 | 01:47 AM
Tdawg's Avatar
I did use my original brackets just had to add alittle spacer on the bottom peg, fixed the gap issue and got the projectors up to the level that i needed them
Old Jul 25, 2007 | 03:40 PM
so these are all made by "Egale Eyes"???
I went to the actual EagleEye website and they only list the older style (non-projector) headlights.
Which seller was the most cooperative and all around better service/price/product?
Old Jul 29, 2007 | 12:24 PM
Tdawg's Avatar
these are the eagle eyes, PM sent
