VHT niteshade on 98-02 camaro headlights?
Is it possible to have VHT niteshade on 98-02 headlights? My buddy has a 99 camaro and kinda wants to do this but isn't sure. I'm worried about the niteshade paint bubbling, fading, cracking or stuff like that over a short amount of time. I know the paint can be put on because the outside of the headlight is plastic. Anyone tried this?
Originally Posted by 1998Z28LOADED
"whistler" mod will give a similar effect, last longer, and look better. IMO
+1 on the "whistler" mod.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I've used Nightshade in the past and have never had any problem with bubbling or cracking. It will fade over time, however, so you might need to reapply every 18 months or so - although that might be a good thing if you don't like the result. I would recommend against doing anything very dark, though... maybe stick with one relatively thin coat.
