So about that Interior LED/Neon/Cathode Idea..
http://randode.net/store/product48.html
http://cgi.ebay.com/Dual-12-Cold-Cat...QQcmdZViewItem
3 choices of almost the same thing, except the 1st are LED tubes, and all totally different ranges of prices. Which would be my best bet to go with?
-Brian
I would rather have it so it turns on when I turn the interior lights on, Ill have to find out how to wire it somehow
This works perfectly, the lights can be turned on and off with the headlight control dimmer switch, otherwise they will turn on when the doors open, and dim out as the interior lights dim out.
**Edit: Couldn't find my picture but I did find the link that I followed http://www.bfranker.badz28.com/fbody/alarm96up2.htm read the part about the "Negative door triger" the white wire shown from the BCM is what you wire your light tube negative to.
