Hood latch mod done: PICS!!!
Old Jul 29, 2007 | 07:48 PM
DOUBT IT's Avatar
Default Hood latch mod done: PICS!!!
After doing the wire mod last week, of course it was time to do the hood latch mod this week. I'm not doing a detailed writeup however, because if you've done the wire mod, the hood latch mod is cake.
Here's what I started with:
A little closer up:
Close up of one of the grounds on the radiator support that I moved under the lower airbox:
Shot of both grounds for reference:
Here's the line-lock wire and hood latch cable. My AIR has been gone a LONG time now.
Where I driled the hole from underneath. I drilled a pilot hole, then used a Uni-bit to widen it to 1/2". No grommet yet, but I'll do that soon I suppose.
Finished engine bay. All that's left is get rid of the TCS controller, and move the line lock to a little more hidden location when I do the ABS delete.
Little closer up:
Now I think it looks better under the hood. I need to get under there one of these weekends and give everything a good cleaning.
What do you guys think?
Old Jul 29, 2007 | 07:51 PM
02NBMFormula's Avatar
looks clean, got any pics of where you put the grounds on the lower airbox? i hate exposed wiring
Old Jul 29, 2007 | 07:53 PM
SsycoticSS's Avatar
awesome!!!!!
Old Jul 29, 2007 | 08:04 PM
johnson7454's Avatar
looks clean! nice job
Old Jul 29, 2007 | 08:16 PM
irbs's Avatar
Cleaning the engine bay is such a pain in the *** but so worth it when you finish.
Looks really good.
Old Jul 29, 2007 | 08:36 PM
Havok2's Avatar
can the tcs system be deleted? i hate it.
Old Jul 29, 2007 | 08:42 PM
Adam_346's Avatar
looks great!
Old Jul 29, 2007 | 09:24 PM
DOUBT IT's Avatar
Where I put them is in the pics. You simply screw them down underneath the plastic with the same screws used to attach the lower airbox assembly. Takes maybe 5 minutes.
Yep. Mine has been non-functional for about two years now. I just pulled the plug from the controller, and have been riding it like that ever since. I'm a lazy bastard who gets pangs of motivation every now and again.
You can delete the hardware as well, you just need a throttle cable from a non-TCS car, as well as a cruise cable from a non-TCS car. You may also need to change TB cams. Do a search, there are several useful threads on the subject.
Old Jul 29, 2007 | 10:02 PM
Havok2's Avatar
doubt it: like if search works lol
pm sent
Old Jul 30, 2007 | 01:20 AM
supersickss's Avatar
what is that red bottle were the batt sits?
Old Jul 30, 2007 | 11:22 AM
DOUBT IT's Avatar
Coolant overflow tank.
Old Jul 30, 2007 | 02:46 PM
Havok2's Avatar
batter in the back i suppose?
Havok2's Avatar
battery LOL my bad.
Old Jul 30, 2007 | 04:21 PM
ReFtheMC's Avatar
Nice, One Day I'll Get A "Pang Of Motivation" To Do It...
Old Jul 30, 2007 | 10:02 PM
Andros's Avatar
why is your radiator shroud gone? Is your car a front breather now
Old Jul 31, 2007 | 11:26 AM
DOUBT IT's Avatar
These cars are supposed to have radiator shrouds?
I took it off when I did the AC delete. More air to the underside of the lid. And yes, it is a bottom breather. If you look at the pics, you'll see that I have the bottom of the lower airbox sealed off, so that the only air the car gets is from the airdam.
Old Jul 31, 2007 | 05:29 PM
Eurospec2's Avatar
clean good job!
