Side molding removal write-up
By the way, after doing this, I love the look soooo soooo much. Its worth it, just wish the one side would of turned out better.
"Goo Gone Spray-on Gel" works great after most of the glue is rolled off. Let it sit and use a washcloth to scrub the little bits off. Use 1000 or 1500 grit sandpaper and running water to get any discoloration off and finish with rubbing compound and waxxing. (My Fiance just smacked my shoulder for the above joke!) Hope this saves you some $$ from a body shop! Good luck! Swat The Best V8 Stories One Small Block at Time
Just did mine this weekend I took them off with dental floss.
I then grenched them in bug and tar remover (gel) and let it sit for a couple minutes.
I then ripped a little bit of clay off my claybar and rubbed the clay into the bug and tar remover right over the glue.
Then just wiped it all of with a clean microfiber.
The bug and tar remover ruinned the claybar, but it actually disolves it into the glue so when you wipe the clay and bug and tar remover residue the glue comes right off with it. This was 10x easier then the method I used before (which actually involved the bug and tar remover...) Just clay alone wasn't enough for me. would have eventually work. Just would have taken another 10-20 minutes...
This removed any lines from 10 year old residue as well with next to no effort...
Molding infront and after door were already missing on passenger side.
After:
Dirt line on driver door:
I think the car looks much better now, and I didn't think that was possible
. I was missing 2 of the pieces on the passenger side and I needed sometime to do the other day. The dirt lines are not noticeable unless you are really, really looking for them, and they won't be there much longer.
