ls1 taillights to lt1 tails.
Old Aug 6, 2007 | 11:49 PM
Havok2's Avatar
Default ls1 taillights to lt1 tails.
i got the wiring (well i dont really, but ill search for that other link in a bit so i can try to understand what was done on the wiring)
BUT, the bulbs dont fit in the stock locations? the ridges are different between the sockets??
Old Aug 7, 2007 | 02:22 PM
Silver35thZ's Avatar
yea, you need a dremmel to make the socket ridges a little bit bigger. thats what i did and they bulbs fit great and there are no leaks in the lights
Old Aug 7, 2007 | 02:39 PM
98redM6's Avatar
Just make the ridges bigger to accomodate the bulbs. It took me about 30 minutes to do all of them using an exacto knife. Just be careful I cut myself up pretty bad. I didn't do the wiring mod but it seemed fairly easy.
Old Aug 7, 2007 | 04:16 PM
Jakson's Avatar
I used a die grinder, took me 30 seconds per tail light.
Old Aug 7, 2007 | 04:51 PM
smg267's Avatar
I just put mine in, Didn't dremel anything. Just alot of patience and cursing!
Old Aug 7, 2007 | 05:34 PM
3.4camaro's Avatar
How do you wire LT1s?
Old Aug 7, 2007 | 06:12 PM
theres a write up somewhere...i haven't bothered to do the wiring, i think you need the lt1 harness for it, and i think its too much of a hassle
Old Aug 7, 2007 | 11:38 PM
Havok2's Avatar
you dont need a wiring harness.
you just splice into it.
look for a write up from XBroKEX
i think
Old Aug 8, 2007 | 02:13 AM
xBROKEx's Avatar
i think
this is the first way i did it, ill do a right up on the alternate way later
https://ls1tech.com/forums/appearance-detailing/741654-how-ls1-lt1-tailight-wiring-pics.html
