Quick question on wire hide mod...
Old Aug 7, 2007 | 09:46 PM
shudog's Avatar
Default Quick question on wire hide mod...
Can't get the abs wire loose to pull it up from the front suspension to the top of the engine bay. I really don't want to cut & splice it but I'm about ready to because I have everything else ready to go. I know there's a clip down there but I can't see it anywhere.
Old Aug 7, 2007 | 11:41 PM
nofearracing28's Avatar
I think i got mine from underneath the car....kinda by the 02 sensor connector. if i remember right.
Old Aug 8, 2007 | 12:19 AM
OhTwo's Avatar
Agree - think I got it off from inside the wheelwell when I had the plastic liner removed.
Old Aug 8, 2007 | 05:15 AM
DopeFedZ's Avatar
I was able to reach it from the top of the engine bay. If you can't that way then try and get to it from the bottom of the car.
Old Aug 8, 2007 | 06:31 AM
shudog's Avatar
I undid the clip right where the connection is, by the control arm, but there seems to be another clip holding the wire in place because I can't pull it up... Would I be an idiot to just cut & splice the wires?
Old Aug 8, 2007 | 06:48 AM
Danny2tek's Avatar
I wouldn't
Old Aug 8, 2007 | 11:51 AM
DopeFedZ's Avatar
You have to pull down on the bottom plug. The top one has a clip of some sort holding it in place to the body/frame. If you aren't able to reach it from the top then you can reach it from the bottom.
