VFN Fiberglass Hood Weight Reduction Questions...
I've been looking at the VFN Fiberglass Hood for a weight reduction mod:
"'98-2002 Stock Flat Pin On Hood. Price=255.00 Weight=12 Ship: Truck Freight.
'98-2002 Stock flat Bolt On Hood.Price=355.00 Weight=18 Ship: Truck Freight."
- http://www.vfnfiberglass.com/site.htm
And I have a few questions:
1. How much does the stock Z28 hood weigh?
2. I have a black car and in the pictures it looks like the hoods are already black, so would I still have to get it painted? If so, roughly how much would it cost to get painted?
3. With the pin on hood do I just have to pin the front down or will I need 4 pins for the front and the back?
4. If I get the pin on hood can I remove the front latch assembly that's in front of and below the air box? Or does this assembly serve as some sort of support peice also?
I've always liked the race look of a pin on hood and I heard somewhere on here that the stock hood weighs ~50lbs, so I think $255 is well worth dropping ~40lbs off the nose of my car. What do you guys think?
I think the stock hood is more like 30lbs.
The black you see on the hood is gel coat and although it looks good now it will start to cloud up if you don't get it painted you can color match it to your car for around 150 bucks.
Not sure about having 4 pins or 2 mine is a pin on and I only use 2 pins in the front and my back hinges for the rear support. About removing the front latch assembly I wouldn't see why you couldn't remove it but thats JMO. Some general info for you I noticed that I run a bit cooler with my fiberglass hood. Good luck hope some of this helps
I've been toying with the idea of using the flat stock pin-on hood. I won't be using pull-ring style pins, but Dzus fasteners, for a more finished look. As far as only using four, I will be doing four on each side, plus those in the front.My only reason for not getting it yet, is I'm not sure how durable it is for daily use. Would it flex and bow too much, and eventually warp?
Thanks for the replies. So no one knows the how much a stock Z28 hood weighs? I'm trying to see if it would be a good weight reduction mod.
I have the VFN stock bolt-on TA hood, it weighs 18 lbs. My stock TA hood weighed 48 lbs. So I got a 30 lb. reduction, and yes the hood comes with a gel coat of dark blue/black. I have not painted mine yet because my car is Navy Blue Metallic and the hood as is blends in with the car especially at night.
The fit of the hood is very good, not perfect but good enough for most people. The edges fit flush with the car body and any rough edges can be sanded smooth when the hood is painted. I've had mine for a couple of months now, and so far it has not warped after being out in the hot sun quite a bit. The hood works great with the latch stuff from the stock hood. It both releases and latches with no problems at all. With both hood shocks on, the hood literally flys off the car when you raise it up.
I will get the hood painted soon, but first I'm looking at doing the Dzus fasteners (2 or 4) on the front edge of the hood. You can remove the hood latching mechanism, one or both of the hood shocks, hardware, cable and lose another 6-7 lbs.
Good Luck!
Good Luck!
Would you have any detailed pics? Details such as what the underside of the hood looks like, would be most appreciated. I am seriously looking for info on making a decision. Thanks
sawedoff. i dont mean to scare you away but my dad bought a fiberglass hood for his '68 camaro and it fit when they put it on but now it sort of bows up in the middle. it looks pretty funky if its on the trailer but when driving around it's not very noticable
Thanks for the help. I was kinda' wondering if these hoods are without alot of reinforcement. I had 65' Shelby that had that same problem of bowing up in the middle.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
sawedoff, I'll try and snap a few pics Sat. morning and I'll e-mail then to you. I'll get both the topside and under the hood for you! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Randy
Randy
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Randy
Randy
I purchase and am in the process of having a VFN SS Hood installed on my 99 SS. I had the hood painted same color as car ( navy blue) blended with the front fenders and had front bumper repainted. The hood looks just aweson and factory. It is my understanding that I will save 27 pounds or so with this hood. The hood is a complete bolt-on and I did not use hood pins. However, I lost my air intake from hood and will come up with something new.
Just a tip:
Don't paint fiberglass panels right away.
They take a long time to cure fully, even though they seem stiff when you get them.
Put the part/parts on the car as they will be installed and drive them around that way for a while so the final curing is done in the same position and enviornment that the part will see after painting. Painting seals the fiberglass and prevents total curing which can lead to problems with both the paint and/or fiberglass in the future.
Good luck
Dave
Good luck
Dave
Just a tip:
Good luck
Dave
Good luck
Dave
Just a tip:
Good luck
Dave
Good luck
Dave
So tempting...
Hood 30 pounds
Aerospace Brakes 38 pounds
KMember/A-arms etc 48 pounds
HALS 8 pounds
150+ pounds off the nose where it counts most and it'll look great!
Chris
Hood 30 pounds
HALS 8 pounds
Chris
