How much to ask for powder coated calipers?
I have a set of 4 calipers for a 98-02 fbody. I think I am going to get them powder coated and then sell them. How much do you think I could sell them for and is anyone here interested in buying them?
I think I was quoted $20 per caliper when I was going to get mine done. I ended up not doing it because I didn't want to tear down and rebuild the internals of them. So if my number are right, that would be $80 plus the $ of your time. I would say $120 or so, but that's just a guess.
I would say not to expect more than $200 for the set. Then take offers from there. Also depends on how good the powdercoating is. Take into account that painting them pretty much gives the same results as powdercoating. It may not be as durable but it's not like calipers are all that exposed. A good paint job on them can last several years. Mine have lasted 3 years now without any chips or flaking paint.
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
What I did was washed them with a brush and made sure they were completely free of any grease, dirt, or contaminants. Then I sprayed them with brake cleaner to get rid of anything else. Let them dry then proceeded to spray them with caliper paint of my choice in light coats. Did about 3 coats with 10 minutes of drying time inbetween. Then did one final heavy coat. Let them dry for about 2 hours, applied my decals, then did 2 light coats, 1 medium coat with clear with also 10 minutes inbetween of drying time.
You can also rough them up with a low grit sandpaper 80-100 or so. This will give the paint something to bite into. Then you can proceed to use primer before the paint. I didn't and still got good results.
