Eagle eye projector help....
Old Sep 19, 2007 | 11:13 AM
B02SS's Avatar
Default Eagle eye projector help....
Just recieved my set of headlights,missing any instructions.
Can anyone tell me where the green and black wires should
hook up? Thanks.
Brian
Old Sep 19, 2007 | 10:36 PM
6LITEREATER's Avatar
No offense but you may be color blind... The wires are blue and black. Mixing green with blue is a sign of one form of color blindness.
Anyways, the black wires you simply ground and the blue wires you hook up to whatver you want to power the Halos/LEDS.
Mine get power when the nitrous comes on but you could splice them into your foglights, DRL's, etc... Or just get a toggle switch and send power to them only.
You could even get a factory foglight switch and add it to your dash OR splice two wires together off the factory switch (the power in and power out wires) so that the foglights are always on when the headlights are on (who ever turns them off anyways???) and then send a 12v ignition power to the switch and run the out wire to the Halos.
Old Sep 20, 2007 | 06:49 AM
B02SS's Avatar
Thank for the help.Your right on the colors,not color blind though
just looked at them under bad lighting,and just noticed 2 bare wires.
Amazed there wasn't any instructions.
Thanks again.
Old Sep 20, 2007 | 05:33 PM
Reject's Avatar
glad you got it figured out, when you asked about the green wire i was all like but glade you got it figured out, where did you hook it up? the foglights like i mentioned to you?
Old Sep 20, 2007 | 07:47 PM
QWIK Z of OP's Avatar
put some pics of the install done!
Old Sep 20, 2007 | 09:31 PM
camaroz87's Avatar
qwik z let me ask you a question or anyone who has these headlights....i just ordered them like 5 min ago and i need to know the bulb size because i know there not 9006 can someone confirm with me if they are h1 or h4????? thanks please PM me
Old Sep 20, 2007 | 09:50 PM
Reject's Avatar
H3's.
