My Xtreme Brake Over...
Old Oct 5, 2007 | 08:46 PM
STRETCH'S T/A's Avatar
those look damn good, and a great price for the whole package. Waiting to hear some feedback on those rotors, that will decide if I get the slotted ones, or order up some Brembos instead.
here's the link to PBT's sale.................https://ls1tech.com/forums/sponsor-sales-specials/779061-pbt-special-front-rear-drilled-slotted-rotors-hawk-pads-269-shipped.html
Old Oct 6, 2007 | 08:59 AM
01Z0H6's Avatar
Thanks for the comments ArcticZ.. Actually, i did come from slotted/cross drilledprior to this set up... I actually had the Eradispeeds..so i am well-versed in the whole blak vs. slotted... The eradispeed actually lasted long than my blanks and were actually maint. free.. and the dust was minimal ( that is due to the pad)..
anyway.the comments are appreciated none the less...
Originally Posted by ArcticZ28
I'm glad they feel good. However, slotted/drilled don't offer improved performance over blanks (if that's what you came from), which I'm pretty sure you're aware of and were just going for looks. But, if you were coming from drilled/slotted already then obviously the last sentence doesn't apply. Regardless, it does look pretty sweet, that's for sure. Say hello to getting used to cleaning off brake dust more often, though
Old Oct 6, 2007 | 09:00 AM
01Z0H6's Avatar
Just to clarify...
I purchased the rotors/pads from PBT... Not the calpers/lines...
Old Oct 6, 2007 | 09:10 AM
WS SIKZ's Avatar
is the stopping power between ceramic and regular any difference or different pedal feel because i hate brake dust.
Old Oct 6, 2007 | 03:02 PM
Tainted's Avatar
Originally Posted by BBADWS6
I disagree that slotted drilled rotors dont offer better performance. They reduce brake fade greatly over stock rotors, the setup looks good by the way!
they fade less because they dont get as hot, but they are also a lot weaker than a simple blank
Old Oct 8, 2007 | 10:17 AM
ArcticZ28's Avatar
Brake fade has to do with heat, which drilling does nothing to help with. In fact, drilled rotors should theoretically get hotter because there is less surface area to dissipate the heat due to the missing material. Venting is what helps cool the disc. Slotting is typically intended to actually wipe away the debris that builds up between the pad and rotor (and there is also talk about the buildup of gases between the pad and rotor but that is more old school oriented for various reasons) so you get a better uncontaminted "bite" from the pad. But, if a slotted or drilled rotor feels better to you, then go with it. Sometimes the mental improvements are worth it (not being sarcastic), not to mention they obviously look better. It just all comes down to whether you're going for looks or actual serious stopping power (which very few people are actually going for or need).
Old Oct 8, 2007 | 10:24 AM
Ericbigmac83's Avatar
Im gonna have to go with artic on this one. its proven, but you all are welcome to disagree all you want
The racing teams which have drilled rotors drill the holes solely for the purpose of removing weight, they have ducting to the brakes so they do not need the extra rotor area for dissapating heat so they can afford to remove some weight by drilling them
Old Nov 2, 2007 | 11:34 PM
SizzlR239's Avatar
thats gonna look good
Old Nov 3, 2007 | 12:40 AM
Psychopjv's Avatar
are those on backwards? i know it is dependent on the vane inside of the rotor, hence me asking.
Old Nov 3, 2007 | 05:03 AM
_JB_'s Avatar
With cheap drilled and slotted rotors it does not matter, I have the same ones. As with the Eardispeeds or whatever they are called, yes it matters.
