Easiest way to install front turn signal lenses?
I just got everything gathered up to swap the front turn signal lenses and before I got started, I was wondering what the easiest way to do it is? Ive heard that you can do it from the top by removing the headlights, is that a better idea? The only other way that I can think of is from underneath by unbolting and pushing that plastic flap to the side. Any suggestions? Oh and Ive got the electronic flashers that I need to swap too, where are they located at? Which ones need to come out and be replaced? Thanks
Never mind, I figured it out. Taking the headlights out was a piece of cake. 1 bolt and slide it to one side and out she comes. It took about 5 minutes for each side. Now all I need to figure out is where the flashers are so that I can replace them with the EL12 Tridon Stant electronic flashers. Where are those located on the car? Which ones will need to be pulled? Thanks
