Hella FF75 Conversion anyone?
Old Nov 20, 2007 | 07:26 PM
phantomzer0's Avatar
Found it for anyone interested:
http://www.dgmotorsports.com/details...&ProcessType=1
Old Nov 20, 2007 | 08:20 PM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by phantomzer0
Damn VIP1 your the ******* man.
Thanks.
Old Nov 21, 2007 | 03:11 AM
TheGr8Schlotzky's Avatar
Originally Posted by whiteheartbeat
Hey,i've done the conversion my car is a 95 i could maybe take some pics cause my car is apart right now so let me know what you need!
Pictures of how you fabricated them on would be nice, as well as maybe some night pics from the driver seat to see some kind of a beam pattern. Did you use the driving lights or the fog lights or a mixture of the two? Where did you get them and how much did you pay?
To VIP1, I'm in stock housings currently. I suppose I could still do the HID conversion to the stock housings, but with the beam pattern they give off, I'd surely be blinding everyone else, and probably not helping myself a whole lot.
Old Nov 21, 2007 | 10:35 AM
VIP1's Avatar
You can modify the stock housings to hold a brighter bulb:
http://performanceworks1.com/headlightmod.htm
I'd recommend a Sylvania XtraVision, GE NightHawk, or Phillips VisionPlus instead of the Sylvania SilverStar. I don't know how the SilverStar Ultra compares though.
Old Nov 21, 2007 | 04:39 PM
whiteheartbeat's Avatar
Pictures i can take, i cannot take pictures of the light pattern cause my whole front end is off the car! Maybe you can send me an email adress so i can mail you some pictures,sorry i don't have them online! I'm not sure if you would be happy, i like them they certainly look better then stock even the lighting is better but i'm not all that satisfied. I used the driving/fog combo and i got them at advanced autoparts,don't remember how much!
Old Nov 21, 2007 | 08:14 PM
So you used the Fog lights for the low beams and driving lights for the high beams? Does the pattern of the fog light have a pretty decent cutoff and such?
TheGr8Schlotzky@msn.com is my email address, thanks
to VIP1, like I was saying, I've already done the sealed beam conversion, but now that I think of it, it wasn't silverstars that I used, but I can't say I remember exactly what bulbs I used. They are certainly whiter, and brighter than stock.
Old Nov 22, 2007 | 03:00 PM
VIP1's Avatar
bump.
Old Nov 22, 2007 | 09:58 PM
VIP1's Avatar
Check out this WebShots Gallery I found:
http://rides.webshots.com/album/62268907BniHSN
Unfortunately, it doesn't say if those are the fog or driving version. Based on the amount of light going upward, I'd guess driving.
Old Nov 22, 2007 | 10:38 PM
VIP1's Avatar
I found a write-up:
http://www.cardomain.com/ride/268472/4
You don't need the relay harness though since the stock bulbs and the bulbs in the FF75 are both rated at 55W.
More info:
http://www.camaroz28.com/forums/showthread.php?t=328722
Thread about building an aftermarket headlight assembly for the 1993-1997 Camaro:
http://web.camaross.com/forums/showthread.php?t=478134
Doesn't look like anything has come out of it yet although I didn't read all the pages (there are 42 pages). I read the first few and last few.
Old Nov 23, 2007 | 12:03 AM
At this point it's down to the beam pattern to make up my mind. If there isn't a decent cutoff or anything, I will probably just go for an HID conversion in my stock housings.
What was this talk about fabbing a projector into my housings? If this has been done, I'm interested to see what's involved and how doable it is.
Again, thanks for all the help!
Old Nov 23, 2007 | 06:17 AM
VIP1's Avatar
Putting HID in moded-stock housings or aftermarket reflector housings will probably produce a worse beam pattern.
I have not seen it done. Its an idea I had. You'd need aftermarket reflector housings with clear front class, then cut the back to mount projectors.
Kinda like this, but for an LT1:
https://ls1tech.com/forums/appearance-detailing/260826-hid-retrofit.html
http://community.webshots.com/album/116863233uyEamc
I don't know if there is enough room though (probably not unfortunately).
Old Nov 23, 2007 | 10:36 PM
  #32
Yeah, I realize that, but I meant if the FF75s don't have a decent cutoff, I will probably just stick the HIDs in the stock housings, because it probably would be a very big difference.
I suppose I could just do a Hella 90mm projector conversion and either drill out the stock glass and have it kinda sit in there and sort of still have the rectangular look...Or I could just put my headlight covers back on and keep them on..
Old Nov 23, 2007 | 11:38 PM
  #33
VIP1's Avatar
Unfortunately, the front glass of the stock housings is rippled which will alter the beam pattern of the Hella 90mm projector.
Old Nov 24, 2007 | 08:23 AM
  #34
VIP1's Avatar
That is why I recommended aftermarket housings with clear front glass, but that adds to the cost.
Old Nov 24, 2007 | 06:18 PM
  #35
Thumbs up
right, but i meant drilling out the center of the glass to have the projector come out of the stock housing but that might look funky...
Old Nov 24, 2007 | 06:42 PM
  #36
VIP1's Avatar
You mean like this?
https://ls1tech.com/forums/showpost....9&postcount=34
Old Nov 24, 2007 | 10:35 PM
  #37
yep that's where I got the idea! I still wish I could find a pic of the Hellas
beam pattern forthe fogs. Ill keep looking. Thanks again!
Old Nov 26, 2007 | 06:06 PM
  #38
Bump. Still looking for a beam pattern on a wall
Old Nov 27, 2007 | 07:33 AM
  #39
Vicious95Z28's Avatar
marcinwz@bellsouth.net
Marcin has done exactly what you're talking about.
Link Removed - CyberSquatter
Old Nov 27, 2007 | 09:01 AM
  #40
VIP1's Avatar
Vicious95Z28, I removed the link because a cyber-squatter took it over.
Is this the site you meant?
http://bellsouthpwp.net/m/u/mulgeary/Hella90/
(the BellSouth email address tipped me off)
That link is listed in the Lighting FAQ.
