What to buy.. Projectors
it looks like a pretty good deal and i heard that those projectors have a pretty good cutoff. just taught u might find it interesting.
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Scroll down to my install.
find yourself a set of e46 bosch bmw projectors or tsx projectors and get them retrofitted into your headlight housings. pick up a "kit" from ledgauges or buy a set of OEM ballasts and bulbs.
https://ls1tech.com/forums/showthread.php?t=710357
I'm planning on modifying the cut-off soon to be square stepped (like a S2000, Audi, etc) instead of slanted and shorten the step-up so I can raise the lights a little more for better down-road illumination on the left and for them to be more level with the ground for a longer distance. They don't look it in that pic, but they are slightly down noticeable at a few car lengths and when driving next too a wall (still further than the stock sealed beams though), but the step is too high for me to aim the lights any higher (the step would probably end up over the trunk of a car a length or two in front of me).
Even left as they are, they are much better than the stock lights. I've had them since spring. I'm happy.
Since you are going to use them in the fog light location, your best bet may be to level-off the cut-off and set the beam level with the ground like a normal fog light beam cut-off.
http://forums.vwvortex.com/zerothread?id=3551726
Hopefully that can give you some insight on what's involved and one way of modifying the shield. Take note of where I explain my extremely slight scratching of the shield in a certain spot and the different light pattern it produced.
My driver-side is now a short square step like a S2000. The passenger side is going to be level and I'm going to aim it to match the high side of the driver-side's step-up.
Since you are going to use these for a fog light, you'd want a level line which is easier to do than the stepped line I made. You can either make a new shield or glue some metal to the existing shield to make a level line (I saw someone do this with some high-heat glue, If I see it, I'll post it).
I'll admit its not as sharp as the original, but its not a mess or color burst. Its more like a larger blue band, which many people aim for. I'd rather have a sharper line, so I worked at it as best I could.
Why don't you think filing would work? We filed evenly/flatly until the line was flat and baby-but smooth. The sharpness that I mentioned is due to the distance of the shield to the bulb. The original shield was stepped inward toward the bulb. After mounting the new shield, I slowly bent it and testing it through trial and error to get it as close as possible. I'll admit its not 100% perfect, but its pretty good. The band is still smaller than when people washer mod other projectors (which gives the large blue band).
Be sure to post up pics when you get them.
people price items on ebay like this becouse of how ebay charges to sell items. if his ebay fee is based on the sale price of the item, its better for him to sell it for mad cheap, and recoupe the money on shipping and only pay for the relitivly small price of the sale, since the shipping cost isnt used to calulate how much he owes ebay for the commision. i havnt looked at the item, so i really dont have an opinion on the quality but i wouldnt nessisarly say its junk becouse of how much the auction is, he is just getting over on a loop hole on ebays pricing.
I think I'm just going to stick with the included bulbs for a while and get an HID kit a bit down the road.
Where did you find those male H9 connectors? [it's the male end I'm going to need, correct?]
(The mounting plates came in that ebay auction you posted earlier, but are sold seperately from Rally Lights....don't forget them, they make installation much easier.)
When I bought a HID kit, I also needed male H9 connectors so that it would connect into the female H9 connectors that I had already grafted into the car's harness for the projectors. You'll need them later also, unless you just want to cut off the female H9 connectors later and graft in the HID kit. I wanted something easily reversible/removable. Unfortunately, it appears that male H9 connectors don't exist so I had to buy two H9 bulbs and break them to use their bases as male H9 connectors.
