What to buy.. Projectors
I think I've read the same thread you read about using a pop can and high heat silicon.
It still needs adjustment though.
The driver-side is square-stepped and the passenger side is straight.
Here is a preview.
No Lights, for reference:
(The white stuff on the ground is snow
)http://www.fadingarrow.com/images/Ne...1_NoLights.jpg
Low Beam Only:
http://www.fadingarrow.com/images/Ne...wBea0mOnly.jpg
The passenger-side can be made sharper (I could have sworn I had it sharper than that before I installed it on the car). I'll have to disassemble it again to adjust.
I did test before closing it up, but I guess it moved before I tightened it all down or maybe I hit it. Oh well. Maybe I'll tackle it tomorrow.BTW, the black bit on the wall appears to be a scorch mark.
Any pics? Links?
For mine, my brother and I made new cut-off shields out of aluminum. We traced out the old one for reference and drew on the new line we wanted. Then used tin snips to get the general shape and files to get it down to the exact shape we wanted. Then we drilled mounting holes in the new shields and mounted them in the original location using the original hardware. After the new cut-off shield and lens were mounted in the projector body, I mounted the bulb in the projector and used a spare connector and pigtail connected to a a jump-pack for power to see the pattern on the wall. I slowly pushed on the new shield to bend it and get a crisper cut-off. The bending was trial-and-error seeing the pattern on the wall.
I think I'm going to jump in to HID, probably 6000K. I'm thinking that mounting them in the fog light area will actually yield better results than the headlights area, because the height difference is only about 6 inches, and because the fog light area is not so recessed, the light should project better down and to the sides.
I'll probably start the installation process when the HID kit comes in, so now I just have to decide on a kit.
Glue + Aluminum Foil
Glue aluminum foil over the angled part.
Like this:
Try this site for help:
http://bellsouthpwp.net/m/u/mulgeary/Hella90/
Mine were DOT.
My brother and I made new shields instead of modifying the old ones because I wanted a new stepped cut-off and I wanted to be able to return to the old shields if it didn't turn out right.
My brother and I re-adjusted the passenger-side cut-off shield today. Its not perfect, but its better. At the same distance as the previous pic, there is still a bit of an orange flare, but as the distance increases, the line changes to a straiter purple line. I had difficulty in getting a line that would look good at short distance and further distance so I went with something that worked better for greater distance.
I didn't take any pics today, but I will soon.
In the end, I'm quite happy. Its not perfect, but its a dramatic improvement over stock.
After looking at the picture again and knowing how those projectors are assembled.... how did you take that picture from inside the projector?
Or you can make a new shield without that stepped down section so that you get a flat line at the height of the "high" side of the shield which is actually the low side of the beam output (the lens flips the light output). Or you can make it a shorter square-step like I did for the driver-side. Since you are using it in the fog light location, you should probably stick with a flat/straight line. That sounds confusing. Let me know if I'm not being clear.
Alright, that makes more sense. I was observing my beam pattern by hooking up the light to my computers power source and I was thinking how much better a line the bottom part is compared to the upper part, and wondering why I would want to add material rather than taking off the step up.
I was actually thinking I may just modify the left light to make it entirely flat, and keep the right one as is for the step up, or I might just add less to that side to keep the step up, but lessen it. I'll probably start this up today.
