Installed the new HID Conversion head lamps, pictures inside
Im curious to see the beam pattern, because when I tried out my HID kit in halogen housings, the glare was unbelievable. I knew it was going to be, I just wanted to see it first hand.
Last time I tried to post about this tho, the post disappeared...
Only H4 style housing Ive seen come close to being tolerable is the E-code housings. They seem to produce the least amount of glare.
Im building a set of projectors for my thirdgen bird, which seems to be the hardest car to try to retrofit into. Bi-zenon projectors for the single headlight guys, and something that is just regular zenon for the camaro, 4 headlight guys. Thats the way to go...but its a lot of work.
Ill reserve judgement til we see some nighttime pics though. If you can, pull away from a wall, maybe 25ft or so. Thats what we need to see. Not a "on the road" shot.
J.
J.
Yes.
Check out the Lighting FAQ.
Its in the Hall of Fame sticky and its in my sig.
Here is a link for convenience:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
You can find these and others in the Lighting FAQ:
LT1 Camaro with Hella 90mm H9 projectors:
http://bellsouthpwp.net/m/u/mulgeary/Hella90/
LS1 Camaro with Hella 90mm H9 projectors:
https://ls1tech.com/forums/showthrea...ght=camaro+hid
http://community.webshots.com/album/116863233uyEamc
If you find other setups let me know and I'll add them to the Lighting FAQ.
#32
Thanks for trying in the snow. You are a brave man drivin in that condition lol.
#34
They don't look quite aimed right.
They look like this:
When they should look like this:
I'm not sure (its difficult to tell from the pics), but the left one might be slightly high.
Can you align them and takes pics again?
So far it looks ok, but borderline a high beam pattern.
Can you turn on your high beams for comparison.
(with and without the low beam).
Can you also take a pic at half that distance for comparison?
Sorry for sounding demanding.
Its the just way I think.
(I'd be taking pics and thinking through it like that too.)
#36
#37
If you want an idea of the kind of pics I'm talking about, check out the pics I posted in my install in the Lighting FAQ.
(I have some pics in the snow in there too.)
#40
I'd get rid of those things and get some projectors. Being flashed is one of the first signs that your lights are too bright/mis-aimed. Not only is what you did illegal, but it's also extremely dangerous. Not knocking you, but just giving you a heads up. You're just giving police officers another reason to cite you.
