Removing sticker glue
Old Jan 27, 2008 | 11:15 AM
taws6's Avatar
Default Removing sticker glue
Hi,
I have just removed the OEM stickers from under the hood, and I think it looks a lot better.
I used an addhesive remover and it worked well, but the glue under the sticker on the battery is resisting my addhesive remover.
Any surgestions for removing this glue?
Old Jan 27, 2008 | 12:12 PM
T/A36's Avatar
Lacquer thinner
Old Jan 27, 2008 | 01:20 PM
aznspeed's Avatar
alcohol, the rubbing kind.
Old Jan 27, 2008 | 01:22 PM
batman08's Avatar
Mr. clean magic eraser works like a charm.
Old Jan 27, 2008 | 01:37 PM
taws6's Avatar
Thanks for info, I'll see which one I can get......
Old Jan 27, 2008 | 01:45 PM
crapyboy750's Avatar
I like using goof off for that kinda stuff.
Old Jan 29, 2008 | 12:47 PM
TheMyth's Avatar
I have used kereosene believe it or not with great success.
Old Jan 29, 2008 | 01:01 PM
Pewter 02 SS's Avatar
Thats what I use as well.
Old Jan 30, 2008 | 06:44 AM
JAXFLSS's Avatar
Turtle wax bug and tar remover will work also.It's all I ever use.
Old Jan 30, 2008 | 02:03 PM
project98LS1's Avatar
a lil wd40 would take it right off
Old Jan 30, 2008 | 02:07 PM
ReFtheMC's Avatar
I used Goo Gone, then after that I claybar'ed and Waxed the area
Old Jan 30, 2008 | 02:56 PM
turbozcamaro's Avatar
I use 3M adhesive remover and it works great
Old Jan 30, 2008 | 03:06 PM
Swiat34's Avatar
+1 on the Goo Gone and another +1 for the Goof-off...both have worked great for me in the past. Just don't let Goof-off stay on any plastic for any amount of time...it'll melt it! Swat
Old Jan 30, 2008 | 03:27 PM
sdm1234's Avatar
goo gone, wd40, lighter fluid, paint thinner will all take it off. if it's in an area that doesn't matter much, you can even use fine sandpaper, then polish the area out afterwards.
Old Feb 2, 2008 | 08:52 AM
taws6's Avatar
Hi,
Thank you for all the replys.
I used the 3M Adhesive remover for the glue and it worked perfectly on all the stickers except the battery one, which was a different type of glue.
So as project98LS1 said I tried wd40 and it came right off.
Thanks for the help,
Hope this helps someone else out too,
Paul.
