anyone here done the push-to-shift mod??
Old Jan 30, 2008 | 12:32 PM
SS101's Avatar
Default anyone here done the push-to-shift mod??
this one from the sticky...
https://ls1tech.com/forums/showpost....57&postcount=1
if anyone has done this, how has it turned out??? was it hard not to cut the plastic shift plunger while cutting the metal??? hows the boot???
in general, how do you like it??
Old Jan 30, 2008 | 03:13 PM
Swiat34's Avatar
I did it. Used the B&M shift **** adapter to mount a Hurst T-handle. I used a Dremel and nicked the plastic a couple times, but if you're careful, that's all you'll get. Just make sure you take good measurements before you start cutting. Measure how for the plastic sticks up, length of the vertical cuts, and how far down the horizontal cut is if you might want to put the stock shifter back on. I cut my stick off where that horizontal cut originally is. COVER YOUR INTERIOR with plastic and maybe put a couple magnets under the plastic to collect all the shavings. Wear safety glasses (goggles are preferred) and latex gloves to protect yourself. After you're done, it looks great and works like it was made that way! Swat
Old Jan 30, 2008 | 03:32 PM
CAMAROZ28AQUINO's Avatar
^^^^ u got any pics? i have a hurst T handle i want to install but i dont know how itll look
Old Jan 30, 2008 | 04:52 PM
Yahelou's Avatar
+1. I would also like to see pics on how it turned out.
Old Jan 30, 2008 | 05:33 PM
Ls1CamaroGuy87's Avatar
Mine turned out great, and I didn't even cut the metal or the plunger......but for some reason people still think that I did
Old Jan 30, 2008 | 05:50 PM
onemaximus's Avatar
I would be interested in doing this but where do you get the A4 Adapter from? I loooked up the part and it did not say anything about the adapter comming with it.
Old Jan 30, 2008 | 05:52 PM
Here you go^^
http://www.ws6project.com/user_stor/...oducts_id=1860
Old Jan 30, 2008 | 05:59 PM
Raptor99's Avatar
I did this too, but it was almost 4 years ago and I don't remember how I did it. I know there was a big PITA somewhere along the way, either with the depth of the adapter or something.
Yeah, I know, I'm a big help
Old Jan 31, 2008 | 06:32 AM
SS101's Avatar
well hopefully the adapter's have gotten better since then...i wish the tutorial in the sticky had a little more info and pix...its hard to get a really good idea of what he's talking about
Old Jan 31, 2008 | 10:12 AM
Red99TA's Avatar
That's a cool mod...never seen it before. I bet if someone tried to steal the car they wouldn't know how to shift!
