Foam Pad Maintenance?...
Only try to clean your pads after they are totally dry. To wash my pads, I use a small, quarter sized amount of Murphy's Oil Soap, and work it in by hand, under running water. Once I have it clean and well rinsed, I will blot it dry, then I will attach it to my rotary, and give it a quick spin at 1000 rpm while holding it own in a 5 gal bucket to catch the sling. (I do this part outside, since I like being married)
then I sit them out in the kitchen table on clean MF towels to allow them to totally dry, then I put them in my cabinet in the garage.
If you are going to put them in ziplock bags, make sure they are 110% dry prior to closing them up, or they will mildew.
As confirmed by Eric at Lake Country, these pads can be washed in the washing machine. Right now I am using the CCS style 6.5" pads for my detailing purposes.
After completion of the detail project, I have washed them together will all microfibers used in the washing machine on the hot water cycle and liquid detergent. The felt backing has never separated from the foam during this time period. The adhesive used is not heat activated on the pads. During the cold water rinse cycle, I will add 1 Tablespoon of distilled white vinegar for each item. This will also help to remove the remaining soap suds from the fabrics and foams.
Once the spin cycle is completed, I will allow them to air dry on the wire rack.
The distilled water is a good pad primer as it will not stain or streak the surface when it dries.
I have a hard enough time getting her to let me wash my towels ..
I may have to just out a machine in the garage. Nice to know you haven't had issues with the Lake pads in the machine.
-Mike
2 words: Clorox Wipes.
The distilled vinegar in the rinse cycle helps to reduce or eliminate the soap scum and product residues from sticking to the insides of the tub. A quick wipe down with the wipes after use and world is perfect again.
