Yet another whole interior upgrade...
Mine next
Looks good.
I hate our interiors.
I was worried about the sun before i did this, so yes i'm still worried. Sun is not good for leather or vinyl, period.
With any luck, everything will go together tomorrow, so I should have some great pics tomorrow night or saturday.
Question , where did u get the vinyl ? The grain pattern is about identical to pattern mercedes uses and exactly what Ive been looking for to wrap the upper dash in my SS .
About Alcantara for those that mentioned it ....its easy to work with but if your not a large wholesaler or have a business account with one its VERY hard to get in the United States . Its also quite a bit more expensive than real suede and real leather .
The door panels were only hard because they had to be disassembled and re-assembled. Re-attaching the insert to the outer panel is not a fun thing to do. I ended up re-using the plastic tabs that i cut off...i just used an aircraft CA glue to re-attach them and it worked fine...but that was yet another pain-in-the-*** to add to the project.
The console requires alot of thought because there is no way to do it without at least two seams, so you really have to think about where you want the seams to end up. I put mine at each end because the front is hidden by the dash and the rear will be hidden by my extended floor/sub box setup that I am doing this summer.
I did not wrap the dash because I am quite happy with it. The new color nearly perfectly matches the dash, and my dash is in perfect shape yet, so I saw no reason to wrap it. I may have a shop do it and put some nice seams in there someday though.
Next phase will be the matching seat covers and i'll probably start on the extended floor and sound system...probably not until June though.
For those asking about the products I used...the vinyl is from Leatherseats, and I will be getting my seat covers from them too. They are very pricey, but i'm very happy with the product. I used 3M spray 80 as my adhesive, and in certain areas I also used plastic epoxy and aircraft CA.
GL with the finishing details ...it will look great with the new seats in there .
