A big black car + Adam's Polishes =
#39
#40
Sure.
1) Wash and Dry the vehicle using an Adam's Professional Wash pad and Microfiber Drying towel
2) Use Adam's Invisible Undercarriage Spray and spray a light coat onto the wheel well liners, this will make the wheel wells almost invisible. Dress tires with Adam's VRT.
3) Clay all exterior painted surfaces and glass using Adam's Clay bar and Detail Spray.
4) Do a test spot using Adam's Swirl & Haze Remover and the orange Swirl Killer Pad with the speed on the PC @ 3500 OPM. Flip the pad over and use the Revive polish to deepen the gloss.
If the swirls and scratches aren't too severe you can use the S&HR with the Revive Polish together 1/3 S&HR, 2/3 Revive polish and the Swirl Killer Pad @ 3500 OPM. Use an Adam's Blue microfiber towel to remove the polish.
5) Once you are satisfied with the clarity of the paint use the black waxing pad and apply a light coat of Butter Wax, set the Speed on the PC to 3000 OPM. Use a blue microfiber towel to remove the Butter Wax.
6) Stand back, admire the shine and have one of these.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
To maintain the shine I use Adam's Detail Spray everytime I wash my cars.
Once the car is rinsed and in the shade, spray the entire car with the detail spray while it's wet, then dry the car.
I hope this helps.
I hope this helps.
