Help me clean up my catch can
This is a old pick it looks alot better under the hood now. See can see it.
-Jonas
https://ls1tech.com/forums/new-products-showcase/856344-1-quart-baffeled-catch-cans-49-95-a.html
There you go
Sorry for the late answer. Great service and a nice product! Edit: Here is a link to the best "how-to" I've seen on the LS1 to LS6 PCV conversion: http://www.ls1howto.com/index.php?article=18
hey i was going through some old posts and i came across one of yours... How do you take the coil pack brakets and top off the valve cover off???
Got a small write up?? I want to paint mine
That's how my current settup is, but i have had the car for 2 months and have already experienced moisture on the inside of the breater. So i will convert back to pcv and with the catch can.
I will mount my catch can on the passengerside cylinder head. draw the pcv from its original posisition to the can. and from my driverside valve cover i will pull a hose to the can for the ventilation. But I will keep the breather on the passengerside as a fresh air resorse.
Hope that helps! I can post pictures when i get started to night or to morrow.
