Help me clean up my catch can
Here are some pics:
Below is a pic of the PCV valve coming off the intake manifold and going to the can. (All the latest cans have an integrated PCV valve in them to avoid confusion)
Next is a pic of the spot where you splice in to the foam covered plastic hose that runs along the pass valve cover. (this application had the optional breather mod and shows the OEM fresh air fitting capped off. Not needed in most cases)
Below shows a supercharged application where it is mounted to the brake booster mount:
And last, a diagram of how a PCV valve works. This is all included in the revised instructions that come with each catch can.
And in different finishes:
Just ask questions if you want more info. The PCV system on our cars is the most misunderstood mod there is & far to many are done wrong. There is even a tuner out there plugging it all off & running open hoses from the valve covers down to the ground where they suck up dust/dirt/water/gravel & who knows what else directly into the valve train!
Hope this helps!
