Porter Cable..My Ass!
I used Simply Z Best....bought it a few years ago at the fair...go figure...I love this stuff. But I'd bet you'd get similar or better results if you used any of the big 3-4 wax mfg's out there
I just thought Id test the theory that you needed to buy a really expensive set up to get good results....All the swirls are gone and the thing looks just like its been sprayed with water...
Besides..what did people use before PC existed....Ive always thought that most of the good products out there are about the same...and with time ( this took 30 min of application and 10 of removal)..taken with minimal hardware you can get good results....
I know I bucking the trend....but hey...its me!
Now granted I did'nt have a really damaged paint job to start with but I did have some swirling.....
Next time I might even Claybar
Then again, I need to order new pads for the thing. I think that is the thing with them, that plus it's pretty difficult to do damage to the car/paint. From what I've come to understand at least.....
Yah dont get me wrong if you've got some real corrections/repairs to make or your a pro and doing several cars a week..your gonna need an industrial strength tool and a PC or UDM is what your gonna need to ...
But If your just and average "joe shmoe" and you need to polish/wax fix some small problems..you dont need to make a huge expenditure to get good results.
Ive seen post where people bad mouth the lower end stuff because its not what proffesionals use...most people diont need proffesional grade tools to get a good results
Before the PC existed, people used rotaries. Since many people discovered rotaries can burn through paint quickly, people started using dual action orbitals.
And Simply Z Best is not a polish. Polishes remove clearcoat to remove imperfections. Simply Z Best is a sealant with fillers to help hide/mask the swirls.
I'm not saying your car doesn't look great. It does! I'm just saying you've proven that a car whose paint is in relatively good shape looks good when you cover it in a filler-based sealant product.
-Mike
Did you use your buffer on the paint without claying first? If so Im willing to bet theres still swirls in the paint. Unless you used a wax (or your last step product) with a TON of fillers in it.... which is coincidently just like the product you mentioned... something youd find at a fair. Nothing wrong with it... just that fillers are a bandaid for paint issues.
I use filler products on customers cars that arent willing to pay for true correction.
To see how well your buffer actually does try this: after buffing with your buffer wipe down the surface with a microfiber using a 50/50 solution of rubbing alcohol and water. Then check it in the sun.... I bet youll be surprised.
The porter cable is a great tool..... however I now use a Hitachi Rotory. The results are outstanding.
Simply Z Best is a non-abrasive, swirl free, Carnauba formula car wax. Z-Best enhances all automotive finishes including newer cars with clear coats and will restore oxidized finishes to a lustrous clear shine. Z-Best cleans, waxes and protects. The cleaners in Z-Best will instanly dissolve road tar, bird stains, grease, road film and bug marks...
Kind of sound like a cleaner wax to me, maybe and All In One (AIO) type of product. Either way its not really going to do anything to remove swirls, maybe cover them up a little. Especially if you are working by hand given the Corvette's notoriously hard clear.
I hope I'm not coming of as an "***" with my posts as it wasn't the intention. I wasn't trying to criticize your results, like I already said the finish looks good. I was just trying to point out that your original comparison of using this product as oppose to a PC was an unfair comparison as they do two different things.
BTW what do you mean by lower end products? I ask because lower end to me sounds like cheap less effective products. However if what you mean is over the counter products then I agree with you. You don't necessarily need boutique products because Mothers, Meguiars and Duragloss makes good products you can get over the counter.
Learn more about polishing over @ www.autopia.org/forum the best auto detailing forum, IMHO.
And Simply Z Best is not a polish. Polishes remove clear coat to remove imperfections. Simply Z Best is a sealant with fillers to help hide/mask the swirls.
-Mike
For every car that I will need to use a machine for buffing, I will test the surface with the baggy test to determine the need for clay bar. Failure to do so and you just asking for more problems when buffing begins.
Those are some impressive pictures after completing the detail.
I like to see my results with the use of halogen or natural lighting during buffing until satisfied.
Yesterday I polished an '05 white C230 that the surface looked like the sample picture posted by Avengeance. Mercedes and others feature cerami-clears that are very difficult to remove scratches with conventional products. I used the UDM with an orange pad at speed 5.5 and Menzerna SIP to remove them. Sorry no pictures were taken. The Menzerna is quite impressive that it finishes down so cleanly that no micro-marring occurred. At $39.99 a quart, it is worth every penny when you get those results.
