Mustang shorty antenna that also works on Camaro
Most do just fine in the city or where there's no obstructions. the problem occurs when you out in the boonies.
One thats cut to teh wrong dimention or one like the Onstar which is built for diffrent frequencies other than radio are not gonna look good.
If your gonna use a cut one then you should measure the antenna and cut it so that the finished lenmgth is a multiple of the total length..
ie if the antenna is 27" long which I think the stocker is then it should be cut no shorter than 9"
Or......
find one with a loaded base made of indestructable rubber and is hand crafted....Hmmmmmm![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Or......
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
