Meguiars NXT tech wax............
Old Apr 20, 2008 | 03:17 PM
davered00ss's Avatar
Moderator
Default Meguiars NXT tech wax............
Bought the stuff last year & was not impressed with it.
Tried it again today. Put it on after wash & clay bar on the SS. Let it sit for almost an hour in the garage @ 70*. Stuff still came off like it was not dry enough. It kind of smeared and left streaks. Had to rub a lot with the microfiber towel to remove the smears.
not finished with the car yet. Only did the hood & front fenders. Just put wax on the passenger side. Just venting about the wax now.
Old Apr 20, 2008 | 03:23 PM
jasonsblkws6's Avatar
Sorry to hear that because i use that wax and love it. Was it humid out cause alot of times i will have trouble if its really humid with it but other than that it dries pretty quick for me unless i get wax happy and put to much on lol. Though i also dont use a microfiber cloth because i use to have trouble with smears marks when i used the turtle ice wax stuff or whatever its called. I now use cloth diapers because they are really soft and seem to do really well.
Old Apr 20, 2008 | 03:27 PM
Moderator
No, I just did my xterra with Mothers wax, and had no problems. Same issue I had with it last year. Just thought I would try it again. I'll stick with the Meguiars gold class for the SS. I have so much F!@#ing wax. Just want to use this up.
Old Apr 20, 2008 | 03:52 PM
haha me too. i got a cabinet in the garage just filled with almost everykind of wax. i used mothers before i used the meguires and i really liked it and worked well. i guess i just like changing waxes up. mothers is really good though because my dad who hates change and use to say nothing beats the good ole' turtle wax used mothers and liked how easy it came off.
Old Apr 20, 2008 | 04:12 PM
95GreenZ28's Avatar
Yea that stuff didnt work out too well for me either
Old Apr 20, 2008 | 04:20 PM
99zman's Avatar
Um do you know how to wax a car???? streaks, not comming off easy? i have never had any of those issues with nxt, and i just got the new tech wax 2.0, havent tried it yet though the car looks like glass after. stop buy ill give you a lesson....
Old Apr 20, 2008 | 04:23 PM
Revelation Z28's Avatar
im using it, i can do the whole car then go back over removing it and itll come right off.
how long did you let it sit for?
Old Apr 20, 2008 | 04:34 PM
MYSTIC-1SC's Avatar
I use the nxt generation wax and really like it.
Old Apr 20, 2008 | 04:45 PM
Moderator
Bitch, get over here and detail my car then.
Old Apr 20, 2008 | 04:46 PM
Moderator
Let it sit for an hour. Just did the driver side and rear bumper & waiting to take it off.
Old Apr 20, 2008 | 05:03 PM
i usually waited 20 min to take it off.
Old Apr 20, 2008 | 05:17 PM
99zman's Avatar
LOL, hows the car working for ya?
Old Apr 20, 2008 | 05:25 PM
bballr4567's Avatar
If its too hard to take off you are putting too much on!!! I did that the first time I used the NXT and it took me forever to get it off. Put it on kinda thin next time and it came right off.
Old Apr 20, 2008 | 05:29 PM
Bird Man's Avatar
I use that wax--put on a thin coat and give it time to cure. It should come off real easy.
Old Apr 20, 2008 | 05:47 PM
TransAmdriv3r's Avatar
I've used it too, I never had a problem getting the wax off (did you spray it down with water and dry it by hand?) but, it doesn't seem to hold up too well. seems like after the 2nd wash it would need another coat of wax.
Old Apr 20, 2008 | 08:06 PM
Moderator
Runs & drives great now. clutch & tranny feel totally different. The TQ arm feels just like the stocker did on the street. No added noise or vibration. You should have come to hanks tonight. There was a small Stang gathering.
As for the wax, not hard to take off, just left smears. Like it was wet or something.
Old Apr 20, 2008 | 08:18 PM
Iron Head's Avatar
A little shot of Quick Detailer will take your streaks off. I also use it with no issues. Dark color too.
Old Apr 20, 2008 | 08:28 PM
BlueBird346's Avatar
I use Meguiars Gold class too and im happy with it. It does take a little longer to dry but its not bad.
Old Apr 20, 2008 | 09:07 PM
raptorws6's Avatar
Thats what i have been using and i have had no real issues. It did leave streaks one time after i was finished, so i washed the car and it was all good.
Old Apr 20, 2008 | 09:12 PM
Gipraw's Avatar
if you are having trouble removing it, then it is probably being applied too thick.
thin, thin, thin is the answer for application .. let it cure 20 - 30 minutes, depending on humidity, then remove ..
another cause for streaking can be uneven application.
Gold Class is a great looking wax, but it has very little durability. if it is your only protection, you need to be applying it frequently.
