!wire mod complete
Thanks!
Black plastic "pine cone" push pins work well also..
All wires that go forward will be routed through the fender wells and/or under the frame. The PCM is behind the firewall, and all engine control wiring will exit from the center of the firewall directly to the rear of the engine.
Thus, very little wiring will be visible when I am done.
Any problems getting a hole saw into that location?
I used my touchup paint to seal the bare metal before I put the grommet in...
Hey Tony....where are you at in town?...maybe we can carve up the cars together?.....I'm on the North West side, 1960/290 area.....
What all is involved?
Tony
Tony
I'll have to refresh my memory, but you need a bi-metal hole saw, and the wires disconnect from the PCM, I think....as well as the vac. hose....
those that have done it, whats involved in removing the wires and vac. hose and re-ataching them?...
Ryan
Wire mod
