!wire mod complete
Old Aug 2, 2003 | 06:56 PM
JPWS6's Avatar
Default !wire mod complete
Did it with no cutting, although the hole ended up being pretty big to get the connectors through.
A couple other pictures I took today...
engine bay
Front
Back
Old Aug 2, 2003 | 07:17 PM
pimpmaro's Avatar
Default Re: !wire mod complete
Very nice. How big and where did you put the holes? Did you seal the wire bundle or anything?
Old Aug 2, 2003 | 08:15 PM
WICKED SS's Avatar
Nice job,
How did you do it without cutting anything? I would like to do this but dont trust myself cutting all those wires lol
Old Aug 3, 2003 | 02:09 PM
theblur98ss's Avatar
Any pics of the holes? I'd love to do this mod but I was always very leary of cutting and splicing. Are the wires long enough? I thought extensions had to be spliced to make them reach.
Old Aug 3, 2003 | 02:54 PM
JPWS6's Avatar
There is only one hole to drill. Hole location and size is the difference between cutting and not cutting. The hole needs to be big enough to fit the connectors through, mine ended up being more of an oval than a circle. The closer you drill the hole to the engine the more play in the wires you are going to have. Just don't drill too far over because you don't want to drill into where the hood strut connects. I should have drilled mine over farther because mine were just long enough. Sorry no picture of the hole, but I will try and take a couple and post them.
Old Aug 3, 2003 | 03:59 PM
MadIceV8's Avatar
Customizing Director
I did mine this past week also without any cutting. The hole does matter, but not a ton if you know the general area of where to cut. I still had a little bit of slack with mine without being too close to the strut connects.
Old Aug 3, 2003 | 05:38 PM
WICKED SS's Avatar
Can someone post a picture of where I should drill the hole and how big? I do not want to cut any wires. Thanks
Old Aug 3, 2003 | 05:52 PM
JPWS6's Avatar
Here is a picture of the hole I made:Hole
It is not a very good picture, but is all I have right now. The hole just needs to be big enough to get the connectors through.
Old Aug 3, 2003 | 08:15 PM
MadIceV8's Avatar
Yep thats basically how mine looks, but I cut a box not a hole . Hey JP, are you the guy that I was talking to at the lemont cruize night? Yea I wasen't in the greatest mood and got a bad spot
Old Aug 3, 2003 | 09:06 PM
JPWS6's Avatar
Yep that was me. I was suprised at the big crowd that was out there. Are you out there every week?
Old Aug 3, 2003 | 11:31 PM
URPREY's Avatar
Here's one of mine. It's a little easier to see since my car is red.
http://urprey.com/photos/firehawk/!w...resopening.jpg
I didn't have to cut anything either. Here's a look at where to mark the hole:
http://urprey.com/photos/firehawk/!w...iresmarked.jpg
I used a 1" hole saw to make the opening, then dremeled it out to fit the connectors through. If you look at the connectors, there is a "cap" on each one of them. If you remove this cap, your hole doesn't need to be as large to pass them through. HTH
Old Aug 3, 2003 | 11:54 PM
MadIceV8's Avatar
JPWS6 - I've been their about 4 times already (Think I only missed one that wasen't rained out). But I'm gonna possibly be their this wed and get a GOOD spot. Then after the show I'm jackin the whole car up and removing everything to be cleaned for Super Chevy . Car won't be runnin till SAT morning. (Took wed-sun off work ).
Old Aug 4, 2003 | 11:16 AM
Xsta Z 28's Avatar
Nice job, Jon! Gald to see you are still working on the WS6 - any swirl marks??
Old Aug 13, 2003 | 12:26 AM
absolut_speed's Avatar
Is everyone painting the metal around the hole to protect against corrosion or doing something else?
Old Aug 13, 2003 | 08:29 AM
Nine Ball's Avatar
LS1Tech Co-Founder
cool post. I never wanted to cut my wires so I avoided doing this to the last car. I think I'll do it to the 35th SS though.
Any problems getting a hole saw into that location?
Old Aug 13, 2003 | 09:16 AM
Sunset01SS's Avatar
Looks very clean. Nice job guys. Definitely added to my To Do list.
Old Aug 13, 2003 | 09:28 AM
Reckless's Avatar
Super Moderator
Nice work, but wait until you see my !wires modifications
Old Aug 13, 2003 | 12:53 PM
JPWS6's Avatar
I cut mine from in the wheel well. Also, unles you make the hole really big you are going to have to make it more of an oval than a circle. I just used a dremel to round it into the right shape after drilling the initial hole.
Absolut, I put some touch up paint on the hole, but you will also want to use some sort of rubber grommet over the hole to protect the wires. I used a small piece of hose and sliced it to fit around the hole.
Old Aug 13, 2003 | 12:57 PM
Reckless's Avatar
Super Moderator
Using hose is a good idea. Some vacuum hose sliced down the middle will snug on there nicely and the sape of the hole isn't as critical when using hose.
Old Aug 13, 2003 | 01:01 PM
NataSS Inc's Avatar
I am going to have to put this on the list of "to do's". I just got through removing the AC and doing the wire mod would make that whole side even cleaner.
