Replacing fogged turn signals
Old May 2, 2008 | 02:17 AM
Ten32's Avatar
Default Replacing fogged turn signals
The turn signal/DRL housings on the front of my Formula are yellow and fogged up from the inside, so I want to replace them. Has anyone purchased new ones before? If so, do the lenses look perfectly clear like the fog lights? It seems that way from the pic I'm looking at, but I'd feel better spending $50 if I knew I'd be happy with the results.
Here's what I'm talking about:
Or.... has anyone tried to replace their ambers with a second set of fog lights? Would they fit?
Old May 2, 2008 | 02:21 AM
cookba's Avatar
just VHT them. $12 and your done.
Old May 2, 2008 | 02:22 AM
Ten32's Avatar
I would (it'd match my side markers), but the fog lights are clear and I want them all to match - and there's no way I'm tinting the fogs. If I had a black car, I'd really consider the VHT.
Old May 2, 2008 | 02:27 AM
Slvr00Bird's Avatar
I really want to replace all of my front lights too.. "ambers and fogs".. I have a formula/firebird front bumper and lights though..
Old May 2, 2008 | 04:09 PM
Ten32's Avatar
Yeah, so do I - that's the problem. I've seen it done on T/A's but apparently no one has tried it on a Formula.
Old May 5, 2008 | 03:08 AM
Ten32's Avatar
TTT... anybody?
Old May 5, 2008 | 06:39 AM
Z-ROC28's Avatar
Take them out, get some 2000 grit sand paper and a bottle of water. Wet sand them for like 5 minutes, take a buffer to it with some rubbing compound and your done. Hardly any money spent . If you don't have a buffer just hand rub it.
Old May 5, 2008 | 06:47 AM
1 Bad Ass Formula's Avatar
They'll be clearer and look a lot better. They can't be as clear as the fog lights because of the Foglights have a clear flat lens while the Turn signal lens has the grid type to t5he inside as seen in the photo above. The fog light housing should not fit since it appears to be a bit larger than the turn signal housing.
Old May 5, 2008 | 02:35 PM
13brian's Avatar
Mine had them clear when I bought the car, I went to replace them with amber- but did not like the look and went back to what was on there. IIRC the specs are for 4157LL and they had put 4057LL in there to be the white ones. They are more milky looking than the fogs, which is why I thought I wanted the amber- but it looked worse. Still milky. Sometime this summer I will pull them out and try to clean them up.
HTH
Old May 5, 2008 | 04:47 PM
Slvr00Bird's Avatar
I need new ones or else I would do this... One all the chrome has peeled off of and condensation has got in...
Old May 5, 2008 | 05:53 PM
Creed420's Avatar
Or you could do what I did.. cost round $8 and a lil bit of time if you got some of the stuff on hand or can find for free! Heres the link if you wanna check it out. Write Up: Formula Front Turn Signals
Old May 5, 2008 | 08:51 PM
transam5.7lt1's Avatar
Are they that expensive?
Old May 6, 2008 | 11:32 AM
Slvr00Bird's Avatar
Not a bad idea
Old May 14, 2008 | 01:45 PM
13brian's Avatar
Nice write up and performance Creed.
