Aeroforce Gauge Help
Old May 8, 2008 | 04:41 PM
ping2day's Avatar
Default Aeroforce Gauge Help
I just installed my Aeroforce gauge. I will power up then turn off. Do the buttons push in to set? Mine seem stuck. I cannot get it to work on my 2000 Camaro SS.
Old May 8, 2008 | 04:48 PM
3800RS's Avatar
when you press the buttons it feels like a click if that helps
Old May 8, 2008 | 05:29 PM
ping2day's Avatar
They do not seem to be pushing in at all. The gauge just blinks a couple of times then powers down. Aeroforce does not have a phone number either. I have to wait to log onto their website also.
Old May 8, 2008 | 09:43 PM
3800RS's Avatar
That sucks, hopefully they will replace it.
Old May 8, 2008 | 11:52 PM
DopeFedZ's Avatar
Try removing the little red jumper that's on one of the plugs on the back of the gauge to see what that does.
Old May 8, 2008 | 11:55 PM
ping2day's Avatar
I believe that is for powering it up with the other cable direct 12v isn't it?
Old May 9, 2008 | 09:57 AM
jeffbab's Avatar
I just power it directly from the computer port, didn't need to hook up the 12 volt.
Old May 9, 2008 | 10:00 AM
ping2day's Avatar
Ok thanks, Mine just keeps cycling on and off if i leave it plugged in. Does yours go off when the car is turned off? I believe the buttons are stuck in on this gauge. They do not seem to move at all. I cannot select anything in this with it in this state. I'm trying to get in tough with Aeroforce now but they only have email.
 Michael S. Palmer
jeffbab's Avatar
Their email for support is:
service at aeroforcetech.com
Old May 9, 2008 | 10:04 AM
jeffbab's Avatar
When I shut the engine off it stays on for a little while, but then goes out by itself.
If you are just sitting in the car then turn the key to accessory, I think it comes on for a little while then goes out.
As long as you have the engine running then it should stay on.
Sounds like yours is buggered. Will probably have to send it back. My buttons make a very slight click noise when I push them in.
Old May 9, 2008 | 10:16 AM
ping2day's Avatar
The buttons on mine do not seem to move at all. I don't know if i should try and pull them out lightly with a needle nose or something. I'm waiting on a reply from Aeroforce. I wish i could just call them.
Old May 9, 2008 | 10:17 AM
PowerShift408's Avatar
Just hook it up to the OBD port. I hooked mine up to a power source at first and it did exactly what yours is. Mine buttons stuck at first as well, but give it a little time. If you still have the receipt, the will fix it for you. Had to send mine back once. Hope this helps.
Old May 9, 2008 | 11:48 AM
ping2day's Avatar
I went out a bit ago to look at it. It just cycles thru the menu then stops on utility then flashes on it for a while then goes off and starts all over again.
Old May 9, 2008 | 12:06 PM
t u n e's Avatar
The buttons are probably rubbing up against the clear plastic lens - where it has the 2 holes for the buttons to come through.
Try shifting the lens around by pushing with your fingers until the buttons move without binding.
Old May 9, 2008 | 12:13 PM
ping2day's Avatar
I'll go out and try that. They might be stuck in causing the guage to just cycle i guess
How do you have it wired up?
Old May 9, 2008 | 07:41 PM
Snuffles's Avatar
When it powers up does it go into the 'scan' mode? (Can you see two parameters?)
If it does go into 'scan' mode, do you have the same parameter up? (ie: Both the top and bottom read oil pressure.)
The buttons are weird. Mine felt like they were stuck in when I first received mine but that's the way they are supposed to be.
Old May 9, 2008 | 10:45 PM
ping2day's Avatar
No it just keeps cycling thru the menu then shuts off. I tried at the track to get it to work, no go. The shift lights were blinking then i got it to just keep cycling thru the menu and could not select anything.
Old May 9, 2008 | 10:58 PM
1fastls1ss's Avatar
Kinda sounds like the buttons are stuck in causing all the haywire you are going through. If they dont click like they should that would be my guess, I wouldn't try taking apart cause that would mean more trouble for you when you send it off to be fixed. They are usually really good about fixing their stuff and getting it back in a reasonable time. My brother had to get his recalibrated for his 97 Vortec motor in his S10 project and when he got it back it worked just fine. I have one as well in my SS and love it with no problems at all. Just email them and they will take care of the rest. Sucks you have to go through it though.
Old May 9, 2008 | 11:04 PM
ping2day's Avatar
Thanks for the reply. Aeroforce replied to try and turn the bezel the opposite direction that the buttons are stuck or rotate the buttons in a circular motion. I have tried this all to free up the buttons. Its still not working. I will probobly have to send it back.
