Should I go even lower????
I have the front Koins set on the upper perch, so I can lower it another 3/4-1" up front, and then I can do the hose mod in the rear as well which should lower me an inch back there.
As you can see below, it's on 19s and I rarely ever drive the car anymore, mainly to work and back once every month or less and to some local car shows and hangouts in the summer. As of now, I've driven it less than 400 miles since August 1st of last year. So a harsher ride isn't too much of an issue to me.
Here's what it looks like now:
And another shot of it in the air so you can see a better ground clearance shot...
So simply from an appearance standpoint, should I do it? Has anyone else done a similar setup with lowering springs and removed the rear isolator and gone with the lower setting on the front KONI's?
Part of the reason for the lift was to get it out of harms way of kids toys and hands.
Thanks guys for all the compliments.
I would never come out of my garage if I had a lift.
