Buffer question
Unless you have previous experience with rotary polisher use, I would shy away from this version unless you are very confident in your ability. Pros use it because it works very fast and saves time.
If you are going to be doing a lot of defect correction, then go with the rotary.
as far as a a rotary goes.. I had my last makita for about 10 years before it gave out .. I replaced it with a Dewalt, and have been pleased with it ..
when the dewalt finally gives up .. I will buy whichever I can get the better deal on ..
Now... my PC collects dust. If its possible I will use my rotary for the whole car. I do still use my PC with the 4" pads for small areas... but thats about it.
If you dont own a machine yet... start with the PC to get your technique down. Once you are comfortable get a rotary and practice on some junk cars... or go to a local bodyshop and see if theyll give you some scrap panels to practice on.
I am also the exact opposite of most people on here.. I probably had 15 years and several thousand cars under my belt before I ever used anything else BUT a rotary.
