zaino questions
i need more ZFX anyways so i'll be ordering some stuff from them, just trying to keep it in one shipment.
also, there are some new products since i've used it. I'm not really sure what CS is used for and what's the difference between the Z-8 and Z-6? Would either of those be visibly benefitial in addition to the usual Z-5,2,6 routine?
CS is a clear coat sealant. It's really geared more towards a daily driver type of car that will see the elements a lot and not a lot of Zaino. If wax your car often, you won't need the CS. If you have a car that really will only be Zainoed once a year, the CS would work.
i'm really not sure about the whole glazing thing either. do you put that on before or after wax and would it even be benefitial with zaino? anyone ever topcoat their zaino with anything?
Glaze is nice to apply over a coat of wax, or on its own, again to give a little extra shine to the surface. True glazes don't have any corrective abilities. They work to hide imperfections with oils and fillers. Since Zaino doesn't mix well with those types of products, it would be best to avoid it over Zaino. You could apply a coat of carnauba over Zaino, but the general consensus is that it really doesn't make much difference; Zaino is pretty darn good all by itself
