is it just me???
Old Aug 12, 2003 | 11:57 PM
Bad 00 SS's Avatar
Default is it just me???
I just put my 18x9.5 chrome Z06 wheels mounted on kumho esta supras 275/35/18s on my car...my car is at stock ride height...it seems to me that they still look like 17s...plz reassure me...I maybe going nutz...I was thinking they have to be b/c of the tire height...plz help...lol...sorry...I juss spent a lot of $ so just making sure!!!
Old Aug 13, 2003 | 12:11 AM
JaxWS6's Avatar
Default Re: is it just me???
Have any pics?
Old Aug 13, 2003 | 12:31 AM
Bad 00 SS's Avatar
no...I got them from AFS wheels...so I'm sure they are 18s...sorry to sound crazy here...I'm juss wondering if ne one else knowz what I'm going thru right now...I just think since I have them on now...its just more obvious that I need a drop...
Old Aug 13, 2003 | 08:23 AM
Nine Ball's Avatar
LS1Tech Co-Founder
17s and 18s have the same outer tire diameter. Bigger wheels do not fill up the fender gaps on non-lowered cars. Bigger wheels only have larger diameter rims, and thinner sidewall tires.
Solution: you still have to lower it.
Tony
Old Aug 13, 2003 | 11:27 AM
Bad 00 SS's Avatar
I want to lower it...but what springs/shocks do u suggest...also...do I need an adjustable panhard rod? I can get an eibach pro kit for $175 on ebay...what shocks do u suggest...thank u for all ur suggestions...keep in mind that I don't want to spend a million dollars and how much will install approx. be?
Mikie
Old Aug 13, 2003 | 11:36 AM
Steve1969LS1's Avatar
Yep.. a 275/35/18 is about the same hiegth as a stock 17" goodyear.. A bigger wheel with a lower profile tire will not fill your wheel well any better..
an optical delusion
Old Aug 13, 2003 | 09:43 PM
SSpilot's Avatar
Go with with Eibach coilover springs, I'm picking mine up this weekend. A little pricy, but you can adjust the hight whenever you want which will help because I read your other post and you said you still wanted to do some engine mods. The adjustable hight will be a huge help when you put in: headers/Y-pipe, sub-frame connectors, gfx or anything else, good luck
