which LED's do I get???
Old Aug 14, 2003 | 11:18 AM
Bad 00 SS's Avatar
Default which LED's do I get???
for clear cornors in order to keep the temp. down so there is no leaking or melting, or whatever the hell is up with these!!!!!!!!! and a part # would help...I thought about just going to pep boys or something...PLEASE help...the clears are going on soon and I really don't feel like buying another set!!!
Mikie
Old Aug 14, 2003 | 11:56 AM
OctaneZ28's Avatar
Default Re: which LED's do I get???
The part number is the same as regular bulbs.
But for reference...
3157 is the larger turn signal bulb.
194 is the marking light bulb.
Old Aug 14, 2003 | 12:09 PM
Bad 00 SS's Avatar
Octane: which bulbs are u running, have u added a bead of silicon, do ur bulbs leak?
Mikie
Old Aug 14, 2003 | 12:22 PM
Camaro SS 2002's Avatar
Exactly what he said. The amber color is best in my opinion. The LED's will not be as bright as the sock bulbs, but as a result the housing on your clear corners will NOT melt. This is the only way to go if you want to avoid leaking.
Old Aug 14, 2003 | 03:50 PM
OctaneZ28's Avatar
No, no silicon, and no leaking problems.
Bought all my bulbs on Ebay... all are hyperwhite.
I'm runnin some cheapo generic 12-LED 3157s and they're dead already.
New 19-LED 3157s are on the way.
For the 194s... got some regular bulbs in there now, soon to be replaced by 6-LED bulbs.
I don't know any of the brand names... I suppose they're all generic.
Also on the way are clear side markers and red 4-LED bulbs for those.
What can I say, I like LEDs.
Old Aug 14, 2003 | 07:04 PM
Bourbon's Avatar
The EL12 Flasher piece is needed to be replaced also right?
Old Aug 14, 2003 | 10:08 PM
OctaneZ28's Avatar
Yes, that is correct. I should've mentioned that.
Gotta switch to the electronic flashers in order for the LEDs to blink with the turn signals and hazards. 2 flashers needed, $7.99 each at AutoZone.
Old Aug 15, 2003 | 06:48 AM
StalkerLS1's Avatar
Don't they make an LED Bulb now that fires Around the sides as well as straight on? I assume otherwise you still have a problem with them looking like a Bright DOT thru the lens if using them in your taillights, etc.
Old Aug 15, 2003 | 11:31 AM
OctaneZ28's Avatar
Yeah, there is those somewhere, but I dunno where to get them.
I've heard that they're like $50 a pair though. But they would make a difference in the front turn signals since now the LEDs point down, and you can't hardly see it at all during the day.
I don't have LEDs in my tail lights.... YET!
