View Poll Results: Paint the berger panel black?
Yes, paint it black
37
84.09%
No, keep it orange
7
15.91%
Voters: 44. You may not vote on this poll
Paint the berger panel?
Old Jun 12, 2008 | 10:12 AM
MEZA TA's Avatar
Flat Black would look real good. IMO
Old Jun 12, 2008 | 10:14 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Originally Posted by mycamaroSS
yea, gloss black with stainless CAMARO inserts will look real good
Old Jun 12, 2008 | 01:31 PM
FadedSS's Avatar
for sure, no question in my mind
Old Jun 12, 2008 | 02:36 PM
z28_YOU_HO's Avatar
what kind of paint should i use?? also, should i sand it down? Im not very educated on paint FYI..
Old Jun 12, 2008 | 02:58 PM
homerunhtr21's Avatar
Just follow this and you will be fine. https://ls1tech.com/forums/paint-body-work/443108-how-remove-paint-make-your-own-berger-panel.html
Old Jun 12, 2008 | 03:55 PM
dutinsss's Avatar
i just did mine. wet sanded with 400 grit wetsanding paper. washed it off. then did about 5 coats with krylon "fusion" satin black spray paint with about 15 minutes in between coats. i used every bit of one can, so i'd get 2 just in case because when they get low, it comes out uneven and can mess it up. its been sittin for about 4 hours now, i'm about to put my inserts and badges on. good luck.
Old Jun 12, 2008 | 07:19 PM
CAMAROZ28AQUINO's Avatar
flat black and stainless inserts would look killer
Old Jun 12, 2008 | 07:22 PM
SSMongoose02's Avatar
I say do it, I wouldn't go gloss it looks like halloween.
Old Jun 13, 2008 | 09:57 AM
kerryt1's Avatar
Yes.
http://www.fquick.com/garages/viewga...id=1&carid=290
Old Jun 13, 2008 | 08:56 PM
raptorws6's Avatar
Paint it for sure.
Old Jun 14, 2008 | 04:25 AM
tektrans's Avatar
don't paint it. car looks great.
Old Jun 14, 2008 | 10:19 AM
  #32
SS14PSI's Avatar
Paint that SUMBITCH! Follow the sticky in the appearance section and you can't go wrong....it's waaaay easy! I did mine in satin black and here's what it turned out like.
Old Jun 14, 2008 | 05:29 PM
  #33
King Nothing's Avatar
yes, go with body color urethane vinyl letter
vinyl is the flimsy stuff that never looks good and sinks into the letters, uretheyne is raised
example:
these are the uretheyne letters from RKsport
and these are the black ones on my red panel
and this is my berger panel
i say body color inserts if you don't have alot of chrome or silver on the car but if you've got alot of chrome or silver than i'd go with the stainless inserts . . . but thats just my opinion
