Polishing Stainless?
Brian: If you get water on your polished stainless covers, the easiest way is to just dry them off as you dry your car. If you let the water spots dry, they can be hard to remove w/o a buffing wheel. Or you can even remove the covers before you wash your car / engine bay. You can use automotive wax to help seal the stainless, clear paint, or clear powder coating.
If you're just cleaning your stainless, you can follow the steps below.
From our site: "Proper stainless steel care can provide a show quality shine for years to come. #8 mirror finish is just as easy to scratch as your cars paint so you must treat it with the same care. Only clean your Specialized Stainless products with clean micro fiber and a quality polish. We recommend "Mothers Billet Metal Polish". You can find this at most auto parts stores for about $15 per 4oz container (remember a little goes a long way). As an example, to clean a battery cover you would only need a pea sized drop. Lightly rub the polish onto the cover with your micro fiber towel until it is evenly coated. Now move to a clean section on your micro fiber and lightly buff the polish off.
The #4 brushed finish is easier to care for. Since it is a directional polished finish, scratches will be hard to see. I would still recommend the cleaning method above but you won't hurt finish of the brushed Specialized Stainless products with conventional cleaning products."
I experimented with my ABS delete block which came as brushed billet aluminum and that's exactly what happened and looked terrible. i ended up sanding out the brushing and then show polishing it conventionally..
