how are frc's attached
Old Jul 7, 2008 | 10:16 PM
Raptor_WS6's Avatar
Default how are frc's attached
how are frc's attached to the engine, i just bought some from a member and waiting for delivery
Old Jul 7, 2008 | 10:20 PM
97ramsst's Avatar
If you look at your coil packs the bottom bolt on 3 out of the 4 on each side holding them on looks like a pointed stud...the covers snap on to those and then snap on to your fuel rail at the top. Very simple install except for all the pieces you have to squeeze them around and under to get them on. Plus your going to have to cut the hell out of those to get them to fit....cut a little and test fit, dont try to cut it all at once!
Old Jul 7, 2008 | 10:32 PM
Raptor_WS6's Avatar
i heard you only cut if you have the AIR in there, mine is out
Old Jul 7, 2008 | 10:40 PM
97ramsst's Avatar
I am not sure about that....maybe you wont have to cut the backs, but I know you will have to cut where the thottle cable bracket is.
Old Jul 7, 2008 | 10:49 PM
Raptor_WS6's Avatar
do you have close up oF pics of yours
Old Jul 7, 2008 | 10:53 PM
97ramsst's Avatar
This is the only one even close to showing the cut for the TB cable. The TB cover hides it but you can see where the corner had to be cut.
Old Jul 7, 2008 | 11:00 PM
Raptor_WS6's Avatar
oh, i see thx
hopefully thats it
does the cable go above the frc's
Old Jul 7, 2008 | 11:07 PM
97ramsst's Avatar
oh, i see thx
hopefully thats it
Yeah, and here is a better pic without the STB and all in the way...
Old Jul 7, 2008 | 11:17 PM
Raptor_WS6's Avatar
perfect thx a lot
you dont have TCS do you?
i have it so i only have one TB cable.... hopefully i dont have to cut a lot
Old Jul 8, 2008 | 11:35 AM
97ramsst's Avatar
perfect thx a lot
Right, no TCS. But I did have it on my Firehawk and I still had to cut them some. I think the bracket is the same size...just no cable there.
Old Jul 8, 2008 | 10:22 PM
Raptor_WS6's Avatar
what did you use to cut it
Old Jul 8, 2008 | 10:25 PM
94TRANS's Avatar
im sure a dremel would work?
Old Jul 8, 2008 | 10:26 PM
97ramsst's Avatar
Yeah, a dremel with a plastic cut off wheel.
Old Jul 8, 2008 | 10:42 PM
Camaro Rick's Avatar
If you know anyone that has a scroll saw, that works waaayy easier. Just go little by little. It took me around 1.5 hours maybe to fit them both. Quite a bit has to come off from one. I'll take some pictures of mine, removed for you if you'd like.
Old Jul 8, 2008 | 11:22 PM
Raptor_WS6's Avatar
pls if you would rick, thx
Old Jul 9, 2008 | 02:00 AM
fast01z28's Avatar
dude, i thought i was doing it for you??? i can use my dremel and cutoff wheel to do it, like i did with mine. you dont need to cut off as much as everyone else...look at mine
Old Jul 9, 2008 | 02:02 AM
fast01z28's Avatar
oh and whats up with the corvette 427? very strange considering those are for an LS1.
Old Jul 9, 2008 | 11:32 PM
Raptor_WS6's Avatar
427
where????
