Turn Signal Problem After Steering Wheel Install
if i turn my wheel a certain amount to each side it will turn on the turn signal to whichever way i turned my wheel. why is this happening?? i can still flip the turn signal lever on manually and that works, but it does it automatically when i turn my wheel. obviously i know i'm going to have take this apart again. %@$%@#^!! but i'm not exactly sure what to look for when i do. what is the steering wheel adapter hitting or not hitting? is there a way i can disable the auto return thing with the steering wheel? b/c i have no problem with always having to move the lever manually. did i fudge something up?? i'm going to try and think happy thoughts to try and calm myself down till i got a clear head tomorrow, any help for me to understand how exactly the turn signal and steering wheel are connected and how screwed i am would be appreciated. thanks!!!
You sound smart, I think you know what you are looking for (something prematurely/improperly turning the return on the turn signal) just keep at it. Wish I could be of more help, only been in there a few times myself
Post pics of the wheel when you get a chance, bet it looks killer!
i'm going to take that off today and look behind it to see if everything is ok and try to get a better idea of how things work back there. if i can get away with only have broken the clockspring, i'll take it. my new plan is to remove that thing from the column, install the wheel, if everything works then i'll get another clockspring, but stick it behind the knee panel and connect the resistors to it. that should turn off the air bag light and hopefully that thing still thinks it's inside the column. first i'm hoping that i didn't break my turn signal switch, b/c i've read the steps to replacing that, and it sounds like a $@%$#. i can still move the turn signal manually and it does turn on the blinker, so the signs right now point to that it's ok. i'm still wondering how it all connects to the turn signal and leading to it moving by itself?? does anyone know how the clockspring and turn signal canceling thing connect? or are related?? i've done a lot of mods but this is the first time i've done an aftermarket wheel on a car with airbags...
If I were you I would pull the airbag thing out, put the wheel back on, pull the gauge cluster out and stick a black piece of electrical tape behind the gauge face where the airbag light is (did this for my SES light before) and be done with it
i saw your post! haha. i was doing my research on issues with aftermarket steering wheels and i saw your post where you posted pics. i was like at least one guy's on my side with this wheel, hahaha.
i'll see what kind of tricks i can pull out my bag this weekend with trying to fix the issue. if my only problem is figuring out another way to turn off the air bag light i'll be happy, i'll even live with the light for this wheel. there's supposed to be a wire for the airbag light under the passenger dash that you can just clip. i might do that if i can't find another working clockspring in the junkyard this weekend. can't wait to get off work to mess with it, haha.
I've never been able to take a clockspring off without it screwing up...
**edit** new clockspring with resistor worked. relocated it inside the dash. done.
