Door Panels
Old Jul 22, 2008 | 05:06 PM
simpleman's Avatar
Default Door Panels
Im sure its been asked before, but does anyone know where I can get new interior door panels for a 99 TA. Or is there a good way to repair old ones and it still look decent.
Old Jul 22, 2008 | 05:28 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Check the for sale section. Are yours cracked?
Old Jul 23, 2008 | 06:02 PM
simpleman's Avatar
Yep, they are cracked. The driver's side is not as bad as the passengers. I know it can probably be repaired, but new ones would look better.
Old Jul 23, 2008 | 07:19 PM
xXSilencerXx's Avatar
Check the Firebird section sticky's, there's a sticky about this with a decent fix.
It's post # 159 that has the fix.
Old Jul 23, 2008 | 07:29 PM
Creed420's Avatar
if they are cracked that bad but dont feel like buying new ones couldnt you plastic epoxy the cracks from the inside, Sand it down somewhat on the outside from any epoxy seepage, then cover them with vinyl? seems like it would be ALOT cheaper and looker better in the long run..
