porter cable detail
Old Aug 6, 2008 | 01:55 PM
xxSCRAPPYxx's Avatar
Default porter cable detail
So, i detailed my SS yesterday. I used the ultimate detailing machine with sonus swirl buster polish on a yellow pad, then i applied a coat of NXT 2.0 wax
Seems like i put some swirls back in it with the MF towels i used, could any one tell me why? they were clean MF towels by the way.....
Sorry kinda crappy pics
Before
http://i104.photobucket.com/albums/m...acation106.jpg
http://i104.photobucket.com/albums/m...acation108.jpg
After
http://i104.photobucket.com/albums/m...acation111.jpg
http://i104.photobucket.com/albums/m...acation114.jpg
http://i104.photobucket.com/albums/m...acation115.jpg
Old Aug 6, 2008 | 02:04 PM
camar0guy's Avatar
should have finished it with a white pad after yellow pad, and less abrasive compund/polish.
then seal it with Zaino, couse it will last longer.
once that nxt stuff wears off in couple of days, u got unprotected car
Old Aug 6, 2008 | 02:05 PM
i could still do that. i got the zaino stuff z5 and z2 think i should apply it??
Old Aug 6, 2008 | 03:27 PM
~RedLineLs1~'s Avatar
Where did you get the towels?
Like most true sealants, Zaino needs to be applied to a very clean surface. If you're going to apply it you need to make sure every bit of the NXT is removed so it can bond properly. An IPA wipedown should suffice.
It appears you did a pretty good job though.
Old Aug 6, 2008 | 05:13 PM
bboyferal's Avatar
You need a high watt halogen or something to get a better look at the swirls while working and the swirls you are talking about because those pics look great to me.
If the Yellow pad you are referring to is a LC Cutting Yellow Pad, then you probably did a good job at getting the big, most noticeable swirls out but added medium swirls/marr in the process. If this is the case, they needed to be removed by a light cutting pad followed by a white pad (ALWAYS A MUST IMO) for the most even layered, high gloss, shiny clear coat possible before sealing it in with the NXT. The white pad is the one that makes a car "pretty." I seriously doubt you did that with the MF towels.
Old Aug 6, 2008 | 09:01 PM
chupr0kabra's Avatar
Excellent advise, my young Padewan.
OP: First, the After pictures are a vast improvement. So, good job!
Second, remember, just because it's microfiber doesn't mean it's a good towel. I have several different brands and varieties of MF towels and they are NOT all created equal. I have some from Autozone that I wouldn't use anywhere near my car, unless it was to clean old grease off of a bushing. Then I have some from a non-sponsor (PM me for the name) that I use almost exclusively and they're GREAT!
Also, how do you care for your towels? I know you said they were clean, but describe your cleaning process. I've seen some really great towels become shop rags simply because someone used dryer sheets or powder detergent on them.
-Mike
Old Aug 6, 2008 | 10:40 PM
by clean i meant new MF towels from auto zone.. the reason i could tell they were making the swirls is because i had shop lights on it when i removed the polish and could see they were coming from where i had just rubbed...any good recommendations on MF
Old Aug 6, 2008 | 10:48 PM
bboyferal's Avatar
You are the master!
It's good when you post.
Old Aug 7, 2008 | 01:14 AM
myfast70's Avatar
You may want to try washing them like recommended above, use liquid dtergent, no fabric softener and no dryer sheets. Also, when you dry them in a dryer use a low heat setting.
Old Aug 7, 2008 | 01:29 AM
since i got lazy and it was in the 90's the day i was working, what is the best way to remove the NXT w/out putting swirls back in the paint? so i can run the white pad and sonus SFX 2 over the car, then the z5 and z2?? thanks for the advice guys
Old Aug 7, 2008 | 06:58 AM
http://www.tropi-care.com/product_p/tc-m7.htm
I love these things. They are HUGE time savers.
-Mike
Old Aug 7, 2008 | 08:16 AM
Brian2006's Avatar
-Mike
Beat me to it
I now have 4 of them because I absolutely love these things.
Old Aug 7, 2008 | 07:43 PM
what is the best way to remove the wax but not lose my results
Old Aug 7, 2008 | 08:59 PM
Gipraw's Avatar
remove the product with a high quality micro fiber towel.
Old Aug 7, 2008 | 09:00 PM
Gipraw's Avatar
that's just wrong.
while NXT is nowhere near as durable as Z, it lasts a hell of a lot longer than two days.
Old Aug 7, 2008 | 10:51 PM
i meant how should i strip the car of the wax so i can apply the zanio on a clean and clear surface
Old Aug 7, 2008 | 10:52 PM
Claybar.
-Mike
Old Aug 8, 2008 | 05:58 PM
98 WS6's Avatar
wash the car with dawn ultra dish washing soap, and everything'll come off. just remember you wont have any wax.
