Can anyone recommend a digital dash
Old Nov 14, 2001 | 06:07 PM
kick_*ss's Avatar
Default Can anyone recommend a digital dash
After installing the ASP pullies and SLP Themostat the guages are off.
After asking about that from SLP and hearing about the pulleys doing the same, I'm thinking about replacing the stock analog dash with digital.
Does someone make them for camaro's?
If not I found a place that I can piece it together but it most likely not look as clean.
Old Nov 14, 2001 | 06:14 PM
Patman's Avatar
Default Re: Can anyone recommend a digital dash
Even if someone made a digital dash for these cars, they probably wouldn't have super accurate readouts. If you want an accurate reading from your gauges, go with some high quality Autometer gauges.
Old Nov 14, 2001 | 06:18 PM
kick_*ss's Avatar
Bummer, wasn't looking to do that but just may have to.
Old Nov 15, 2001 | 08:40 PM
gpierce's Avatar
No one makes a digital guage panel for these cars yet. I have a feeling that they won't ever due to the design of the pod and the fact that there is not much room for any add on panels inside the pod.
In my experince, all the digital panels are a pain to install, and they never seem to work right. I installed those cyberdyne panels in a 90 Mustang I used to have. They never worked right.
GP
Old Nov 23, 2001 | 04:11 PM
99 Black Bird T/A's Avatar
Before you buy...be sure you see a simlar gauge in operation...some update to fast and are annoying to try to read...personally I'd stick with analog.
