water spots
Old Aug 8, 2008 | 12:29 PM
wormy01SS's Avatar
Default water spots
anyone know any good ways to take water spots out of glass. windex and normal glass cleaners doesn't work. any suggestions..
Old Aug 8, 2008 | 08:02 PM
5PONT7's Avatar
Glass polish with a machine orbital. Works great!
Old Aug 8, 2008 | 08:46 PM
TARaptor's Avatar
if they aren't etched in which is rare then the cheapest and easiest way by far is vinegar. You can just use straight vinegar if its just on your windows if you have spots on your paint mix 50/50 water and vinegar to use less vinegar.
Old Aug 8, 2008 | 08:50 PM
camaro-94-z28's Avatar
i think this thread is started once a month. someone make the biggest one about it a :sticky:
Old Aug 8, 2008 | 09:46 PM
Breathtaker's Avatar
Vinegar or Zaino.
Old Aug 9, 2008 | 10:50 AM
wormy01SS's Avatar
I had someone else tell me vinegar but i wasn't too sure about that. But i guess i will give it a try. They are driving me crazy
Old Aug 9, 2008 | 11:39 AM
BadMrFrossty's Avatar
I spray alittle bit of Eagle One Wire Wheel cleaner on glass and LIGHTLY rub an SOS pad over it and it's quick and easy and works wonders. Only took an hour to do front and rear glass and ttops.
Old Aug 10, 2008 | 03:09 PM
SpdFrk1990's Avatar
This guy used metal polish not sure if this would work on the t-tops or not cause that is whats spotted on mine.
http://www.detailingworld.co.uk/foru...ad.php?t=79859
Old Aug 10, 2008 | 05:04 PM
ZaneO's Avatar
Distilled white vinegar, claybar, glass polish, etc.
Old Aug 10, 2008 | 08:47 PM
boostinsteve's Avatar
What about if they are etched in?
Old Aug 10, 2008 | 08:52 PM
som1sc's Avatar
Triple ought steel wool will take the spots out without scratching the glass is what a body shop told a friend of mine.
Old Aug 10, 2008 | 09:14 PM
LS1_Unleashed's Avatar
I use a product made by a company that produces detailing products(non-sponsor) but the stuff is called wheel magic. If anyone wants to know where to get it from just p-m me.
Old Aug 11, 2008 | 04:22 PM
ZaneO's Avatar
Fine steel work can work in some circumstances, but it's extremely important to be very careful when going that route. Once glass is scratched, it's not likely coming out.
Old Aug 11, 2008 | 05:45 PM
LETHLS1's Avatar
like som1sc said, triple ought steel wool with glass cleaner works perfect. my dad owns a body shop.
Old Aug 11, 2008 | 06:12 PM
LS1Z28's Avatar
I use ZEP tub and tile cleaner takes off the all the water spots. Just make sure you rinse well if you use it. You can buy it at Homedepot.
Old Aug 11, 2008 | 07:28 PM
thecobrahunter's Avatar
Clay bar here. Windex...on your paint? Ayeeeeee!!
Old Aug 11, 2008 | 07:37 PM
Crimson's Avatar
Get Zaino http://www.zainostore.com/Merchant2/...oduct_Count=16
I've used it on 4 different cars/trucks with bad water spots on the glass and it took them all out with a lil' elbow grease. It's very safe, not like using ACIDIC wheel cleaner, or steel wool.
