Fog Light is Burnt out...how do I replace??
Old Feb 9, 2010 | 12:00 AM
Storms of War's Avatar
4th gens were still in production when this thread was started
Old Feb 9, 2010 | 09:55 AM
Danny2tek's Avatar
glad to know the search works
Old Jun 19, 2010 | 08:50 PM
TruBloodTransAm's Avatar
Originally Posted by xxtinktFormula
You can gain access by flipping the lights, but you need a 3 year old hand to do it. Look under your front bumper and remove the 10mm bolts that line around the front edge. pull down on the plastic panel and stick your arm up. twist and pull.
Aside from the 10mm bolts, do you also take off the three plastic rivets? If so, what's the best way to "unlock" them?
Old Jun 19, 2010 | 08:54 PM
SparkyJJO's Avatar
No kidding... wow that's scary almost.
Haha yeah, better than we could say a little while ago
Old Jul 19, 2010 | 05:32 AM
Snake_Skinner's Avatar
^ Ever figure that out Tru Blood, my fog light just went out so its my turn?
Old Jul 19, 2010 | 03:51 PM
BadCompany VP WS6's Avatar
Needle nose pliers. Grab the centers, sqeeze and pull.
Old Jul 19, 2010 | 05:24 PM
Yea I bought two new fog light housings off ebay and swapped them in a few weeks ago. Go under the car and you will see three black plastic rivets holding a big plastic cover behind the fog lights. Use a flat head screw driver and dig into the side of the river, between the head and the washer. Then use some pliers or channel locks and yank out the rivet by the head. That's the easiest way to pull them out, they're easy to put back in as well. There is also a 10mm bolt over by the passenger side that may need to be removed to give you better access to the fog lights. Again, this 10mm bolt is part of the big plastic cover behind the fog lights.
When you get to the actual fog lights, you should see two 10mm bolts which fasten the fog light housing to the chassis, go ahead and remove these. Also, go ahead and unplug the connector going to the fog light bulb. If you can, try to unplug the bulb and remove it, or you can do it when you pull the housing out.
The best way to get the housing out is to go to the front of the car and try turning the fog light 180 degrees and slowly pulling it out. This is the easiest way to do it, trust me, I spent a while trying to yank it out, but if you twist it around 180 degrees, it comes out much easier. Do the same when you install the new housings.
That's about it, let me know if you have any questions.
Old Jul 19, 2010 | 06:17 PM
BTW, I have two sets of stock fog light bulbs, if anyone wants them for free I'm in the Dallas area.
Old Dec 24, 2010 | 11:58 AM
82cetuner's Avatar
you still have them?
Old Dec 24, 2010 | 04:35 PM
Yup, PM me if you're in Dallas and want to pick them up.
Old Dec 24, 2010 | 09:18 PM
bad_408_vert's Avatar
there's almost some comedy in this thread.
