Keyless reciever?
Old Nov 26, 2001 | 06:09 PM
c4c5specialist's Avatar
Default Re: Keyless reciever?
Hi there,
Sorry, it is in the body control module. And you must calibrate it to your car.
Sorry, c4c5
Old Nov 26, 2001 | 10:08 PM
Pete2k_Z28's Avatar
Thanks c4c5, someone on LS1.com made a mention about a Theft Deterent Relay. Do you know anything about this? Would I only need this if my car did not come with the factory alarm, or is this a specific part of the keyless system?
I'm getting the BCM from the same guy I got the remotes from, so hopefully I'll get lucky and be able to skip the step of calibrating it to my car.
Thanks again, this helps me out very much.
Pete
Old Nov 27, 2001 | 12:39 AM
Pete2k_Z28's Avatar
Default Keyless reciever?
I'm trying to add keyless entry to my car. I have two factory remotes alreay, but I need to know where in the car is the reciever, and how hard is it to remove from another car? Anybody have an idea?
Old Nov 27, 2001 | 04:18 AM
HI there,
In that, you are talking about a different part of the system. You see, the theft relay is part of content theft, and is on a different part of the system.
You are looking for keyless entry, and this has no bearing on that, as the relays for this function are within the receiver.
Besttoyou, c4c5
Old Nov 27, 2001 | 09:56 AM
Pete2k_Z28's Avatar
Yep,that's all I need is the keyless. I just wanted to make sure that this relay had nothing to do with disarming the alarm; it would suck to have my alarm go off every time I opened the door!
Thanks again!
