FRC install...HELP
TIA
Note: Be very careful with the "fuel line" closest to the front of the car. There is an EVAP module connected to it and it breaks very easily. At least mine did.
Sorry, can't help. Good luck though. I'd ask Steve2000SS if I were you.
I'll be sure to be careful around that EVAP line.
There's a black electrical box that sits on a metal clip. I have no idea what it is or does. I removed the clip and it sat lower, but still not right.
Make sure you have cut out a large enough notch in the rear(no one will ever see it) to fit the AIR system. The key is it should but up next to or even slip under just a bit that AIR valve in the rear under the windshield cowling. Also, you may need to make a small oblong notch on the rear fuel line slot facing the front of the car to allow the FRC to slide as far back as possible.
I will be the first to admit the driver's side is a PITA is get in by with some minor adjustments it will go.
From the looks of your pics you are real close because the cut on the the top side of the cover line up with the humps on the intake pretty well.
Bryan
I made a pretty huge cut in the rear of that driver's side cover, but I'll check it again and try that notch idea for the fuel line.
Thanks again guys
The two pics at the bottom might help a little. Let me know how it goes.
